firebirdStud 09-16-2006, 03:50 PM Ok, before you get mad, here is the background:
I asked about updating the tranny program before for a fully built tranny from Frank at CPT.
Everyone said stock programming is fine. OK.
But, now I got to thinkin, does things have to change for the tranny, being that it will sit behind a 440RWHP Naturally aspirated motor?
So, taking all this into consideration, now what would you suggest?
:D
thanks
Cody
Sweetred95ta 09-18-2006, 11:14 AM If you're making that much power, I would think that you have a bigger cam, that would require a higher shift point. Adjust that and you'll be fine.
firebirdStud 09-19-2006, 10:04 AM Yeah, custom cam from Advanced Inductions. So, what is the formula for figuring out shift points? Like I said, I am new to this, and I want everything to play well together when the new Auto goes in this winter! :o)
Sweetred95ta 09-19-2006, 10:19 AM Frankly, I can't even remember what the tranny tables look like. I will try and look at them when I get home tonight. I'm not sure if there is a formula; just trial and error to get it honed in perfect.
infinitebird 09-19-2006, 11:06 AM Yeah, custom cam from Advanced Inductions. So, what is the formula for figuring out shift points? Like I said, I am new to this, and I want everything to play well together when the new Auto goes in this winter! :o)
There is no formula, it's not like there is only one correct value. Shift point is more of a preference. Play with it a little and see what you like. Do some datalogs and see what rpm/mph you are at at certain places and adjust as needed to be where you want.
firebirdStud 09-19-2006, 10:25 PM oh ok. So if you dont like being at 1500 at 65 mph, just adjust the shift point so it stays in 3rd until 70 or something like that? I know, rough guess, but is that the logic you use? I am just trying to see how to go about this after I install the auto tranny and new dana 60 this winter. I wanna pull her out and start driving it after minimal "messing around." But this doesn't seem to hard to do, if I got it.. if the way I explained is correct above... :D
s_willis 09-20-2006, 05:01 PM Here's what you need to do. Put the trans in, drive it like your going to drive it. and decide spcefically what you want it to do different and then ask how to change it. I think you'll find that the trans tables are going to be real close as they are. You will probably want to shift at different rpms at WOT and that is where you need to know what hp and tq numbers your engine has in order to decide when to shift at WOT.
2QUIK6 09-20-2006, 05:26 PM As explained, its completely trial and error...but it can get confusing because when you raise your shift points....you'll also have to change the downshift points as well...otherwise for example...you to shift to 4th at 45mph...now you raise that to 55....your driving down the raod at 60 in 4th gear....you slow down to 40mph and your still in 4th gear because the old downshift point was never changed...so now with the new cam your lugging at 40mpg in 4th gear when it should have downshifted.
There's also TCC lockup to factor in and a set of tables for that and the lockup release...if you are not careful, you'll have the TCC locking up at the same time you shift into 3rd or 4th gear which is not good.
When I put the LT4 in the truck, the stock Camaro settings in the PCM would not work at all in my truck with the factory truck gears....took me about 6 months of on and off tweaking to finally get it right and then I still made some minor changes every once in a while for the next 2 years after alot of daily driving and noticing some things.,.... but you should not have that much to change unless you are drastically changing the gearing in the rearend when you go with the Dana 60.
Also, there's not just mph to factor into the shiftpoints, there's TPS and if I remember correctly a table called something like "Time spent in each gear" for WOT that is used in conjunction with rpms and TPS.
firebirdStud 09-20-2006, 11:02 PM holly crap. This just got overwelming. Well, looks like I will just trial and error it. once I get it in, then I guess I can have specific questions, and then I can get help changing stuff. I just want to make sure I can drive it on a stock program first off, so I have somewhere to start! Thanks guys!
Sweetred95ta 09-20-2006, 11:41 PM Half of the tables are dedicated to transmission controls. Did you think it would be easy?;) :D
s_willis 09-21-2006, 09:04 AM holly crap. This just got overwelming. Well, looks like I will just trial and error it. once I get it in, then I guess I can have specific questions, and then I can get help changing stuff. I just want to make sure I can drive it on a stock program first off, so I have somewhere to start! Thanks guys!
It will run fine on the stock settings, don't let anyone tell you that you have to change all kinds of things. The only things you will probably want to change is the WOT shift points, and you might find that you like them like they are. It has been my experience that only when you change the converter to a higher stall, that you might want to look at changing the part throttle shift points.
Sweetred95ta 09-21-2006, 10:53 AM I would think that with him making 440 rwhp, he'd have a higher stalling converter. It probably would be pretty doggy down low w/out one. :shrug:
firebirdStud 09-21-2006, 01:02 PM yeah, I am looking at the yank 3600 as its a daily driver first... I think its the SS3600 but not sure...
2QUIK6 09-21-2006, 02:50 PM yeah, I am looking at the yank 3600 as its a daily driver first... I think its the SS3600 but not sure...
yep, going to have to change the shift points in that for sure. The stocker program/tables will work, just maybe not as efficient as you'll want it for a daily driver...just put it in a see, you may feel that no changes are needed, but you'll find there will be a few times it will not act quit like you want and you'll want to change it.....
In my truck..there's was one little window of mph where if I nailed the throttle it would not downshift for anything..like when jumping out in front of traffic on the highway...and I about got creamed a few times cause it wouldn't downshift and accellerate......things like that you'll discover after driving alot.
firebirdStud 09-21-2006, 11:14 PM Haha. I am hoping that doesnt happen to me, pulling out in traffic and getting creamed! lol. Well, guess we will see what happens in the spring when I pull her out of storage with a new auto! :D
