Lt1 and Ls1
09-15-2006, 01:46 PM
So what all do I need to check to see what the problem is. I cant even lift it up when the lights are on
One of my headlights isnt coming upLt1 and Ls1 09-15-2006, 01:46 PM So what all do I need to check to see what the problem is. I cant even lift it up when the lights are on moparman 09-15-2006, 03:12 PM Have you tried the manual way by turning the device that will raise and lower the lights? Sometimes I have to manually raise one on my car, and that seems to fix it for awhile. Lt1 and Ls1 09-15-2006, 03:57 PM I will try it thank you. Not to sound like an idiot but can you tell me how :o moparman 09-15-2006, 07:30 PM Raise the hood and locate the headlight motors. There is one beside each headlight bucket. They probably have a rubber cap on them. Remove the rubber cap and see if you can turn the motor by hand to raise the headlight. Lt1 and Ls1 09-15-2006, 07:46 PM Okies thanks floraelianor 09-16-2006, 03:37 AM does it make a wierd sound or just the head light grear is not functioning? __________________ 1997 TA. Ram Air, 17"wheels, Borla 3" exhaust pipes, supper light Wilwood brake kits 1973 455 SD TA Lt1 and Ls1 09-16-2006, 10:34 AM It is just not coming up, no noises floraelianor 09-18-2006, 02:30 AM Had the same problem. I changed the gear and it did not work. the problem was from the Headlight module located just above (the driver fender) or litle bit behind the air filter box. On way to make sure that the Headlight module is the problem, try to connect the left headlight electrical connection to the right and viceversa. If the driver side is working and the other one is not then definitly the problem come from the Headlight module. In my case, I had a bad IC connection on the board of the headlight module. Lt1 and Ls1 09-18-2006, 07:47 AM TY I will check it out | ||
