Resilient94LT1
09-15-2006, 01:48 AM
I'm looking into a DHM e-cutout for my 94Z. I have the 3" Magnaflow on stock manifolds. Does anyone have experience with one of these? Did you install yourself or bring it to a muffler shop? Would a basic muffler shop install an e-cutout or is it too complicated? Next, how did you route the wiring into the car? If I were to bring one of these to be installed at a shop, what kind of change am I going to expect to put up?
Sorry for all of the annoying questions, I just figured I would cover my bases. Thanks in advance!
nodnarb481
09-15-2006, 07:06 AM
an exhaust shop probably wont run the wiring.. you can do that and its not to hard if you have a snake... installation shouldnt be too much.. chop the pipe, weld in cutout, done. I say no more then $50 for installation. Im installing mine of my full hooker exhaust right after the y-pipe soon. its not electric tho
anasazi
09-15-2006, 08:14 AM
have the exhaust shop install the actual cutout, runs about $40 - $50 under the table around here.
install the electric part of it yourself, you don't want some exhaust monkey messing with electrical stuff. its real easy, hardest part might be finding a wire to tap into for power, i think i tapped into my cig lighter wire and havn't had any problems.
94_PatriotRed_Z
09-15-2006, 08:34 AM
What they all said... but do a search on here, aorund March or April someone posted a real nice write up on how to wire the electric cutout
Stoopalini
09-15-2006, 10:01 AM
As stated, bring the cutout pipe to a shop and have them weld it in right under the pass rear seat. This cost me $30, Then drive home and do the rest yourself.
There is a rubber grommet right below the rear pass seat, and you can use this to run the wires inside the cab. I cut a slit in the grommet, slid the wires through, then used a generous amount of silicone to seal it up. Come up under the carpet to where you are going to mount the switch. I mounted my DMH switch under the ashtray lid, right next to the ashtray. For power, I soldered a blade connector onto the power wire and slid it into the fuse box to an accessory connector.
This is a great mod, even if it's just for the "Fun Factor" alone :D
Thomas.
teke184
09-15-2006, 10:56 AM
you won't pick up much power with the coutout over the magnaflow setup. it flows so well to begine with.
i had a cutout on my old magnaflow setup, and it was dynoed to show a 4hp gain over the exhaust.
Resilient94LT1
09-15-2006, 12:56 PM
Thanks for all the replies guys, i'll certainly do a search to see the best method of installing the "e" portion, although Stoopalini seems to have a great idea there.
I think the gains will almost become secondary to the "fun factor" as stated above. :) Any gain would be satisfactory but im sure i'll smile every time I open her up.
94_PatriotRed_Z
09-15-2006, 01:57 PM
the write up descirbes the same why he just said with pics and how too.
I found it
How To: run the wires for an Ecutout (http://web.camaross.com/forums/showthread.php?t=392423&highlight=cutout)
