Victor intake for lt1
Hcastle97
09-14-2006, 03:11 PM
I wanted to see if you can make a Victor intake fit on Afr 220 Lt4 > heads...
Sorry,
I've never done this. But I have a good idea of how. I just don't have a set of LT1 heads to verify they fit afterward.
Basically you weld plugs in all the stock victor bolt holes except for the 4 outer ones.
You then weld a triangular shaped pc of AL over the two outer bolt holes at all 4 corners.
Then drill the new holes at the correct angle.
Then get your intake flange surfaced from the inevitable warping caused by all the welding.
You could also leave the two center holes by the plenum alone and drill/tap the heads.
This would save lots of time. Assuming the heads are off the motor of course.
How big a hurry are you in?
I might start working on the jigs needed to do the drilling in December or so. Maybe later.
This would be a side project for if and when I had time unless your interested.
And I have no idea at this time what it would cost.
But just the welding and intake flange machining would be $150 to $200.
i wanted to know if there is anyone else that would want this
OldSStroker
09-14-2006, 06:57 PM
Try this thread for info and pics.
http://web.camaross.com/forums/showthread.php?t=465663
The "Search" function here is your friend. Try searching on "super vic".
