Went to the track tonight.
Old Sep 12, 2006 | 10:01 PM
Nick-LT1's Avatar
I ran 3 times and ran 3 13.20. I dont think i did that bad. All runs i ran 106 mph. I know that the car has more in it because of the 60'. The best i could do is a 2.1 and the other two were 2.2. I was spining the first time then i just babied it out the the hole the second two times. I am going to go next week with my bfg's and hope to hit a high 12. I dont have subframe connectors so i dont know if the drag radials is a good idea tho.
Old Sep 12, 2006 | 10:12 PM
Tyler_LS1's Avatar
Re: Went to the track tonight.
sounds good! i wonder what my times would be?
Old Sep 12, 2006 | 10:56 PM
Bayer-Z28's Avatar
How would SFC effect the Rear?... My buddy ran through two sets of drag radials and beat his car kinda good, the rear never gave him problems.. had minimal mods, tho.
Old Sep 12, 2006 | 11:22 PM
GhostZ28's Avatar
SFC's help prevent unibody twist off the line when you're pulling 60' ers near 1 sec. Only crazy HP cars tend to twist the unibody enough to do damage.
Kinda rule of thumb there is, If your front wheels are coming off the ground, then SFC's are useful. But then again if your car is doing that, you've probably already got a 8+ point roll bar which ties your unibody together as well as SFC's so its almost redundant
Old Sep 13, 2006 | 12:18 AM
AL SS590 M6's Avatar
Moderator
13.20 @ 106 is a good number for street tires. Get a 2.00 or better 60' and you'll be real close to a 12.
And if your car is an a4 then don't worry about the subs yet. But if it's a stick then you can dimple the rear 1/4 panels stock on street tires. I know this for a fact because the proof is in the driveway. 98 SS stock best pass of 13.30 @ 107 and it's got dimples in both rear quarterpanels. I like to powershift.
Old Sep 13, 2006 | 03:45 PM
Nick-LT1's Avatar
its a auto so i guess i will go back next week and see what she does on drag radials!
Old Sep 13, 2006 | 03:46 PM
Nick-LT1's Avatar
is 13.20 good for a full exhaust auto car?
Old Sep 13, 2006 | 06:34 PM
teke184's Avatar
with a 2.2sec short time...yeah...haha
Old Sep 13, 2006 | 08:08 PM
mook99TA's Avatar
don't let the A4 fool you I cracked my dash on street tires at the track without SFC's. I hooked really well with 20psi in the tires and pulled a 1.8 which is outstanding for street tires but ended up with a cracked dash.
Old Sep 15, 2006 | 05:44 AM
darrens99formul's Avatar
With drag radials you can easily hit a 1.9 60'. That right there should put you around a 12.9
Next mod should be a stall. 3500 stall with tranny cooler and say hello to mid 12's!
Good luck at the track.
Old Sep 15, 2006 | 05:56 PM
Nick-LT1's Avatar
Well i would really like to get a stall because i know at this point it would help out a TON but i dont have money for something that expensive right now because of college. Maybe next summer! Right now i i think i might be able to afford a LS6 intake with a ported TB.
Old Sep 16, 2006 | 06:13 AM
I hear ya. My TCI SSF3500 was $500 for the converter, $50 for the trans cooler and $350 for the install. But it was the best $900 I ever spent
Old Sep 18, 2006 | 06:05 PM
wdtiger's Avatar
Seriously, i'm not trying to be a smart ***, but if you can't afford a stall, how can you afford an LS6 intake and a ported TB? Does someone make really cheap intakes and TBs i don't know about?
Old Sep 19, 2006 | 05:12 PM
Nick-LT1's Avatar
Well you can get a LS6 intake for $350ish and my buddy can port TB's. But like the other guy said it cost him $900 for converter, cooler, and instal. I could put a intake on my car but i wouldnt want to pull the tranny to put a converter in the car. Plus i dont want to risk blowing the tranny, and right now i drive alot going to work and school so i need gas mileage for a few more years.
Old Sep 19, 2006 | 08:50 PM
robb4964's Avatar
If you tune it youll pick up 2mph on your traps.
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
