2ktransam
09-12-2006, 12:16 AM
What setting should I use for my QA1's for maximum traction and which hole should I use on my LCA relocation brackets? Also should I remove my front sway bar? Here is my setup.
BMR torque arm on set to -1
BMR rear sway bay
QA1's all four corners 300lb springs in the front, stock springs in the back
BMR LCA's and relocation brackets
17" MT et street radials
Prostar skinnies in the front
Strange 12 bolt 3.73
raceweight is about 3600lbs
BMR rear sway bay
