JASON96Z
11-13-2002, 05:22 PM
I know you can solder a resistor inside obd 1 pcm to work with the obd 2 knock sensor, but I can't find out what value and where to solder it. thanks for any help guys.
what resistor do i use to make obd 1 pcm work w/ obd 2 k.s?JASON96Z 11-13-2002, 05:22 PM I know you can solder a resistor inside obd 1 pcm to work with the obd 2 knock sensor, but I can't find out what value and where to solder it. thanks for any help guys. madwolf 11-13-2002, 07:16 PM 3.9K resistor. Solder between pin 22 of Blue connector and ground. | ||
