95 N2OT/A
09-11-2006, 02:42 PM
94 camaro z28
complete LT1 pullout with 87k miles runs perfect with all accessories, PCM, and wires attached to a stock 4L60E tranny- $1700 for the combo or $1400 for the motor and accessories and $400 for the tranny OBO
A4 radiator-$80
fan assembly-$80
complete headlight assembly-$100
steering fluid resivor $20
coolent resivor $25
washer fluid resivor $10
A/C condinser-$40
dash-$125
e-brake handel assembly-$25
e-brake cables (all 3)-$30
center console with A4 plate-$50
HVAC control panel-$25
headlight control panel with fog light button-$20
steering column with airbag and wheel-$150 or $50 for the bag and $100 for the column and wheel
passenger air bag-$40
window/mirror controls-$40 for the pair
hood struts with brackets-$25
hatch struts-$20
red camaro z28 hatch with spoiler-$50
black leather door panels-$80 pair
rear view mirror-$20
both side mirrors in black-$30 each
gauge cluster with 87k miles-$40
defrost button-$5
A4 pedals-$40
seat belts in charcole-$60 for the complete set or $30 for the fronts and $30 for the rears
key fob-$10
sunvisors in good condition but the elastic straps are loose-$25 pair
t-top weather strip (does not leak)-$40
t-top divider on the roof-$15
t-top mounting brackets-$15 set
t-top headliner with a small cig burn-$25
t-top holders that mount in the trunk-$30
a pillars-$40
b-pillars-$10
gray dome light-$10
drivers door in red with new window motor-$100
yellow front turn signal lenses-$20 pair
tail light no cracks-$60 pair
tail light wireing harness-$20
red beager panel-$30
hatch weather strip-$10
spare tire-$20
a-4 steel driveshaft-$40
stock torque arm-$20
323 complete stock rearend-$250
k-member-$50
motor mounts-$40
complete spindel assemblies-$100 pair
rear brake calipers-$80 pair
4 stock rims with bald tires-$80
steering rack-$40
charcoal interior panels- make offer
gauge bezel-$20
red camaro z28 hood-$40
95 formula
stock cat (it should be good but i don't know for sure it came with the car)-$20
dash-$150
drivers door (needs window motor)-$75
3-channel abs module-$40
t-top a-pillars-$50
passenger front fender in silver-$60
rear bumper in silver-$40
t-top shades in charcole-$30 pair
complete set of gray cloth seats-$100
PCM-$80
MAF-$40
headlights with motors in silver-$150 each or $260 for the pair
stock rockers-$20 set
brand new water pump-$100
tail light center panel-$30
heater lines-$20
gray cloth door panels-$50 pair
LT1 block with pistons, rods, and crank worked perfect when pulled-$150
LT1 oil pan-$60
k-member-$50
steering rack-$40
front bumper support (the foam thing with the bracket)-$30
valve covers-$25 pair
a/c compressor-$50
brake booster-$20
M6 radiator-$80
fan assembly-$80
smog pump-$25
hatch in silver-$50
gas tank-$20
e-brake handel-$25
t-top holders in the trunk-$30 pair
upper dash pad (the clips that hold it down where it meets the main dash are broken so you will have to hold it down with double sided tape)-$60
LT1 wireing harness-$50
M6 steel drive shaft-$50
headlight support bar-$80
complete horn assembly-$25
yellow front turn singnal lenses-$25 pair
complete intake with throttle body, injectors, MAP sensor, fuel rails and the regulator-$150 or
stock throttle body with all sensors-$40
stock LT1 intake manfold-$60
stock injectors-$30 set
stock LT1 fuel rails with regulator-$50 set
MAP sensor-$20
hatch weather strip (does not leak)-$10
radiator support-$20
fuel lines-make offer
center console with M6 shift plate with a broken boot ring-$60
belt tensioner pulley-$25
headlight controls-$20
hatch release assembly-$20
gray dome light-$10
brake master cylinder with resivor-$20
washer fluid resivor-$10
front strut assemblys with new shocks-$80 pair
side mirrors in silver $40 each
k-member bolt set-$10
stock PHB-$20
gas tank straps-$20- pair
LT1 dip stick assembly-$20
96 camaro z28
defrost button-$5
white z28 spoiler with 3rd brake light-$30
gauge bezel-$20
hood hinges-$20 pair
10 bolt housing-$80
k-member-$50
rear dif cover-$20
stock pinion-$20
97 trans am
fog light switch-$15
passenger interrior mirror trim-$5
steering column with airbag and wheel with volumn controls-$160 or $50 for the bag and $110 for the column and wheel and volumn controls
factory amp-$40
owners manual-$7
starter with only 76k miles-$60
brake booster-$20
PCM holder-$5
motor mounts-$40 set
passenger t-top with key $160
stock stall-$20
complete 323 rearend-$250
98 camaro z28
stock injectors-$50 set
stock fuel rails with pressure regulator-$50
HVAC controls-$25
tan hard top headliner-$30
3 channel abs module-$40
red camaro z28 hatch with spolier-$50
drivers door in red-$100
e-brake cables (complete set of all 3)-$45
gas tank straps-$20 pairstock LCA's $20
hatch struts-$20 pair
rear tan seat belts-$30
factory amp-$40
tan interior plastics-make offer
shock sensor-$10
tan dome light-$10
drivers mirror and window control panel-$25
rear axils-$25 each or $40 for the pair
tail light harness-$20
15 stock lifters and rods with only 42k miles-make offer
door handes bezels-$15 pair
dash-$160
door panels in tan leather-$50 pair
LS1 k-member-$50
brake booster-$20
complete set of tan leather seats in poor condition-$50
other parts
Vats bypass module-$15
hatch pop buttons-$5 each
camaro z28 3rd brake light-$10
10LB edelbrock N2O bottle with pressure gauge-$100
cig lighters in gray and black-$7 each
97 firebird v6 rear springs-$30 pair
stock torque arms-$20 each
global west abj PHB-$80
pirelli scorpion zero 285/50 R 18 with only 1k miles look new-$300 for all 4 tires (they are sport truck tires)
all prices are OBO and plus shipping
i'm located in mansfield tx 76063
my paypal is misdswimmer@hotmail.com
thanks
robbie
A4 radiator-$80
fan assembly-$80
coolent resivor $25
A/C condinser-$40
dash-$125
hatch struts-$20
defrost button-$5
A4 pedals-$40
key fob-$10
a pillars-$40
b-pillars-$10
gray dome light-$10
spare tire-$20
k-member-$50
motor mounts-$40
steering rack-$40
gauge bezel-$20
95 formula
dash-$150
t-top a-pillars-$50
PCM-$80
MAF-$40
heater lines-$20
LT1 oil pan-$60
k-member-$50
steering rack-$40
a/c compressor-$50
brake booster-$20
M6 radiator-$80
fan assembly-$80
smog pump-$25
hatch in silver-$50
gas tank-$20
e-brake handel-$25
MAP sensor-$20
gray dome light-$10
stock PHB-$20
96 camaro z28
defrost button-$5
gauge bezel-$20
10 bolt housing-$80
k-member-$50
rear dif cover-$20
stock pinion-$20
97 trans am
factory amp-$40
owners manual-$7
brake booster-$20
PCM holder-$5
stock stall-$20
98 camaro z28
HVAC controls-$25
factory amp-$40
shock sensor-$10
tan dome light-$10
dash-$160
LS1 k-member-$50
brake booster-$20
other parts
thanks
robbie
