Tweaked Zed
11-13-2002, 01:17 PM
What kind of numbers are people getting with good port jobs on AFR LT4 Heads? I'm thinking of running one of the new Comp Cams Xtreme grind hydraulic rollers and staying under the 7000rpm limit of the pcm. So now, what would anyone recommend for size? It'll be a 410ci. Thanks guys.
AFR LT4 210cc
AFR LT4 220cc
AFR LT4 227cc
P.S. I realize the 227 is probably too big for a hydraulic, but just in case someone HAS done it. I see that there IS a CC Xtreme with 248/252 dur@.050, so it's not totally out of the realm of possibilities, is it?
I posted on the Tech board but the only respnse was from 4drLT4. If you'd like to email me privately with any info, that would be cool to.
AFR LT4 210cc
AFR LT4 220cc
AFR LT4 227cc
