350 HRSS
09-05-2006, 02:00 PM
I know the intake gaskets are supposed to be reusable, but I am asking anyway to be sure.
I have the stock intake off my car, and will be changing over to the FAST. Just need to know if I need to change the intake gaskets/seals or not. They look fine, but there was a little imprint of oil from the gasket on the heads when I removed the intake. Does that mean they are need to be replaced? Or do I just switch the old ones over to the new intake?
I called around and most auto parts store are in the $29-35 range. The dealership has them in stock, and MY price is $50 (they list for $70).
Just wanting some advice.
Thanks!
iamsickofitall
09-05-2006, 02:11 PM
as long as there aren't any indentations along the edge that makes contact with the head and they stick out of the intake far enough to give a good seal, then they're good to be reused.
i reused mine when i swapped to a FAST intake
350 HRSS
09-05-2006, 03:36 PM
Thanks for the reply! I just went ahead and ordered the FelPro gaskets from Advance for $29. Rather be safe than sorry :)
Thanks!
Capn Pete
09-05-2006, 04:16 PM
For the cost of them, I would probably replace them. I'm sure over time the heat would start to break them down and/or make them more brittle. For a few bucks extra, better be safe than sorry:thumb:.
350 HRSS
09-05-2006, 04:27 PM
That's what I figure, why not save myself the time and trouble!
2001NBMZ28
09-05-2006, 04:37 PM
Yeah, don't want to have to take it off again...helped do a couple and we always used new gaskets.
AL SS590 M6
09-06-2006, 01:06 AM
They are totally reusable. Even in the GM service manual it says to inspect them and if they are not damaged then reuse them.
They don't seal anything except for atmospheric air. No oil, no water.
You could spend that $30 on something else.
350 HRSS
09-06-2006, 08:51 AM
So what were the oil gaskets prints on my heads when I took off the intake?
iamsickofitall
09-06-2006, 09:07 AM
You are sucking oil vapor into your intake through the PCV system. This is a common issue with LS1's. A catch can will stop most of the vapor from getting into the intake.
350 HRSS
09-06-2006, 09:18 AM
Might as well just go ahead and do the PCV mod. I just ordered the parts.
psychocabbage
09-06-2006, 09:24 AM
On my LT1 we dimpled the surfaces then used RTV and done..
AL SS590 M6
09-06-2006, 09:48 AM
LS1 is a totally dry intake. There is a valley pan under it that is bolted to the block. So the fix you're outlining has no place on the LS1, thank god.
The intake gaskets are 8 port shaped quad rings that fit into grooves in the manifold and seal up around the intake ports on the head.
