Anyone rebuild TH350's? Couple questions and pics inside...
BOOSTEDGTA
09-03-2006, 10:59 PM
I have been experiencing a "clicking" sound coming from my TH350transmission that sounds like the old 'cards in the spokes' from childhood bicycle days.... the sound was consistent with wheel speed, NOT engine RPM. And it would do it regardless of the gear it was in, 1st, 2nd, 3rd, neutral. Anyway, I traced the noise to the tailshaft section of the trans so today I pulled the tailshaft off. I was thinking it was going to be something with the speedo gears messed up... but what I found was a cylindrical piece loose on the output shaft, and it was cracked on the end (rim was about half sheered off). I think this may be called the "case bushing" but not sure. So my questions are as follows (see pics below):
1) Is this the case bushing and is it supposed to be pressed into the end of the tailshaft?
2) Should there be a clip holding the speedometer drive gear in place? There was no clip present.
http://webpages.charter.net/boostedgta1/IMG_0567.JPG
http://webpages.charter.net/boostedgta1/IMG_0570.JPG
