what spark plugs
Old Nov 13, 2002 | 02:01 AM
BlueLS1Z28's Avatar
what spark plugs
i want to change my plugs,what dose everyone else use with good luck?
Old Nov 13, 2002 | 04:51 AM
Ghost SS's Avatar
Run NGK-TR55's
Old Nov 13, 2002 | 08:02 AM
ShaneS's Avatar
I second the NGKs... good stuff...
Shane
Old Nov 13, 2002 | 08:04 AM
bbentley40's Avatar
I plan on using the TGK's when I change mine. Anyone have a good wire preference?
Old Nov 13, 2002 | 02:15 PM
Ghost SS's Avatar
Stock wires will last for a long time....a good 100k miles out of them.
Old Nov 13, 2002 | 02:44 PM
bbentley40's Avatar
I know the stock wires will last a while.. but are they as good as an aftermarket set? I have always heard to go ahead and replace wires when you replace plugs anyway.
Old Nov 13, 2002 | 04:07 PM
jd13's Avatar
I plan on running NGK-TR55 in my car. What gapping should I go with? Only some bolt ons are planned in the near future.
Old Nov 13, 2002 | 04:58 PM
toykilla's Avatar
NGK TR6
Old Nov 13, 2002 | 05:30 PM
Ghost SS's Avatar
NGK-TR6 plugs are good...if you need a colder plug, like if you run nitrous(which I do).
NGK-TR55 is the plug you should use with simple bolton cars. Generally, for every 50 hp that you add you need to decrease the gap by .004. If you add 150 hp over stock you should decrease the gap .012. So .060 is the stock gapping...and you decrease the gap from there depending on how much hp you have added.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
