96z
11-13-2002, 01:00 AM
When you do the swap what do you do? Just reflash your PCM with an M6 specific program?
Simple A4-M6 swap question96z 11-13-2002, 01:00 AM When you do the swap what do you do? Just reflash your PCM with an M6 specific program? SteveR 11-14-2002, 01:11 AM Yes, and the car will run/drive with the A4 program. It will throw some tranny codes because the A4 isn't there, but other than that it is fine. There is no such thing as an A4 PCM or an M6 PCM. Both PCMs are the same part #, they just have different flash files loaded. 96z 11-14-2002, 10:01 PM Really?? So I can leave the computer as is with my A4 program and drive it with no problem besides codes? Interesting....Ill probably reflash it with a M6 program anyway, thanks! Lt1tko5o 01-06-2003, 02:16 AM You willhave to change your Vss calibrations for the M6, I did the reverse swap and my speed O was way off, had to flash in the A4 program and the speed O is now accurate. Brian | ||
