Gaskets for a 3970010 block?
Old Aug 28, 2006 | 10:57 AM
Wishmaster's Avatar
I have an early 3970010 block drivers side dip stick that Im using for my 383...I need to get an oil pan gasket for it...someone told me that they do not make 1 piece gasket for the older blocks...true?..if they do make one does anyone know the part number or can point me to one?
also Ive been reading and what is this about on the 1 piece having either the thick style front seal of the thin style front seal? how do I know which one Ive got?
thanks
Old Aug 28, 2006 | 02:22 PM
Stephen 87 IROC's Avatar
Re: Gaskets for a 3970010 block?
The front seal for the oil pan depends on the pan and timing cover, not the block. Typically, oil pans from 75 and up use the thick front seal. 1974 and eariler use the thin front seal.
Aftermarket timing covers are designed for the thick front seal.
Felpro one piece gasket for LH dipstick and thick front seal is #1880
Felpro one piece gasket for LH dipstick and thin front seal is #1885
Both are in the $30-$40 range from Jegs or Summit.
Old Aug 28, 2006 | 02:39 PM
Wishmaster's Avatar
Im using an aftermarket oil pan, what kind I have no idea but its aftermarket...and of course Im getting an aftermarket timing cover...so should I get the thick front seal gasket?
I want a 2 piece timing cover but if I get a one like say from AZ or Advance..would that be considered aftermarket?
Old Aug 28, 2006 | 10:23 PM
ws6transam's Avatar
I'm using an early 1969 block, casting number ...something...something...388. It's from a Nova SS, 350 4-speed car I think. Anyway, I've got a one-piece gasket in there, but I forgot where I bought it from. They are made, and you need to simply trim off the appropriate tabs to use it as either a passenger or driver dipstick oilpan design.
Old Aug 30, 2006 | 09:03 AM
Wishmaster's Avatar
I just had a brain farT!....if my dipstick is on the drivers side...what would that be called? LH or RH?..I guess it depends on how you look at it..
Old Aug 30, 2006 | 10:36 AM
Z28SORR's Avatar
NO, it's always left to right as you sit in the car. Drivers side is left, pass. side is right.
It's the same with ALL vehicles; boats, trains, planes, and auto's. Except with boats it's port and starboard.
Old Sep 4, 2006 | 02:05 PM
Wishmaster's Avatar
http://store.summitracing.com/partde...&N=700+150+150
will this work? I assume its for either and like you said, you just trim the other tab off..
Old Sep 4, 2006 | 09:11 PM
ws6transam's Avatar
Yes, that looks like the kit. '55 to '85 will cover that 0010 block just fine.
Old Sep 18, 2006 | 07:29 PM
mrr23's Avatar
all after market oil pans use the thicker front seal for the oil pan gasket.
Old Sep 19, 2006 | 08:55 PM
tom2's Avatar
The all years set should have both thin and thick rubber seals.
Sergio
Jan 27, 2016 04:27 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
4586
Apr 29, 2015 01:43 PM
carl.froehlich
Mar 13, 2015 12:38 AM
