What amp would you use?
Old Nov 12, 2002 | 09:08 PM
weak95bird's Avatar
What amp would you use with a Alpine SWR-1241D and why? hehe need help here
Old Nov 13, 2002 | 01:21 AM
NineSevenWS6's Avatar
Something about 500w, maybe class D.
Old Nov 13, 2002 | 05:52 AM
rthompson's Avatar
yep, i concur
Old Nov 17, 2002 | 07:44 PM
Klypto's Avatar
JL 500 mono is nice.. not cheap though...
(its 500w RMS)
Old Nov 17, 2002 | 11:57 PM
weak95bird's Avatar
Would a Kicker 02KX600.1 work? 600w at 2ohm or should I run it at 4 ohms? I got a good deal on it if it is a good amp any one have one, if so what are your thoughts about it?
Old Nov 18, 2002 | 01:10 AM
firebirdude's Avatar
If you are looking for the best dollar/watt ratio then try the JBL 600.1 It will put out near 700 watts at 2 ohms and is stable to 1 ohm. The only problem is that it lacks the bells and whistles of a more expensive amp. i.e. subsonic filter etc....
Old Nov 18, 2002 | 11:53 PM
badasscamaro's Avatar
Talking
I would go with an alpine mrv 1507, it puts out 1500 watts
max and 1000 continous.The reason being is if you ever upgrade you wont have to buy a new amp. You can just turn down the gain to the desired level but be careful not to blow them.You may think thats way to many watts but believe me you will always wanna change for better stuff, I went through about 8 systems before I found the perfect one.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Bobczar
Oct 23, 2015 11:22 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
