Air only blows out of the floor vents
Old Aug 23, 2006 | 05:36 PM
speed_demon24's Avatar
I fixed my intake manifold oil leak, and now the air only blows out of my floor vents. It doesn't matter what setting, a/c, heat, vent, defroster, ect, it only blows out of the floor vents. I'm guessing theres some valve or something that determines the airflow, but I have no idea where its at to check it.
Old Aug 23, 2006 | 05:43 PM
96capricemgr's Avatar
Re: Air only blows out of the floor vents
vacuum is used to move that stuff. Check on the passenger side of the intake that is where the tube is and it runs into the wiring harness. Maybe you forgot to hook it back up or it got pinched or cracked?
Old Aug 23, 2006 | 06:08 PM
Greed4Speed's Avatar
Check vacuum as stated. When you have a leak it defalts to this position.
Old Aug 23, 2006 | 06:35 PM
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
Old Aug 23, 2006 | 07:30 PM
I just checked and that vacume line was off. Thakn you.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
PROJECT X
Apr 17, 2015 12:13 AM
95chwagon
Jan 13, 2015 09:19 PM
Britbilly
Jan 7, 2015 08:49 PM
