Raising back end up
surf121
08-22-2006, 09:52 PM
I was having issues with my rear 315/35/17's rubbing the already rolled fender lips on my lowered (Eibach) SS. I put in some of those coil things in the back springs and raised the back end up about 3/4 and inch as a temporary fix for the problem. That was all the room I needed, but I'm looking for a more permanent solution to my problem. Anyone have any ideas? Thanks
Greed4Speed
08-22-2006, 10:02 PM
Which Eibiotch springs do you have?
stopthatman
08-22-2006, 11:07 PM
Ground Control rear weight jackers and 150 lb linear springs
Dave '97 Z28 M6
08-24-2006, 12:48 AM
Have you done all of the stuff suggested here to fit the 17x11's:
http://web.camaross.com/forums/showpost.php?p=3422887&postcount=8
OBE1 95Z28
08-24-2006, 02:54 PM
Is your axle perfectly centered (left to right)? If not, an adjustable panhard rod will let you center the rear to improve clearance for the 315's.
surf121
08-25-2006, 03:39 PM
I've got the Prokit. I have done everything on that site to help them fit, including a panhard bar. The axle is centered and everything. It doesn't rub as of right now because of the spring inserts that I put in, but that is not the end all/permanent solution that I'm looking for.
What are Ground Control weight jackers and what exactly are linear springs.. I'm not very knowledgable on the suspension aspect of things. Do they make the car handle worse? Thanks for the replies, Logan
84firebird
08-25-2006, 11:16 PM
how about a set of gabriel highjackers, what $75 and you're done raise it however much you want up to around ~5 inches
BLACK Z !
10-21-2006, 09:57 PM
Hi, I was wondering where did you get them? how much where they and how did they go in? also can you adjust the height by adding or subtracting them? I lowered my car and would like the rear to be a little higher. Thanks
Greed4Speed
10-21-2006, 10:27 PM
Thats great if you don't mind wheel hop.
