Sensor on the brake pedal assembly......?
Blue96z28
08-21-2006, 10:31 AM
I'm doing the t56 swap, and I dont know - what is the sensor which is located above the brake lights/cruise sensor, same style, in all the time(off), and then out to activate, but I don't know what it controls or if I need to reinstall it on the m6 pedals, the guide does not mention it at all, it has a small plug with 2 wires.....is it maybe the sensor for the auto shifter to allow you to shift from park once the brake pedal is depressed????
davidarel
08-21-2006, 08:52 PM
The brake switch should have the battery power going in and then a lightblue coming out to the brake lights. This switch should also be the cruise release switch. the other switch should be for the shifter lock. I am not positive about the colors since I am not looking at a scematic.
Blue96z28
08-22-2006, 01:52 PM
ok, sounds about right, guess theres no need to even have the shifter lock out switch on the pedal assembly now then, thnx
