Fuel filter placement & braided line routing
blown383
08-20-2006, 02:51 PM
I'm looking for pictures of the way you guys routed your braided hose from the tank to the rails. I have a 12 inch long fuel filter that I'm having difficulty finding space to mount so I thought it would be easiest to mount it in the drive shaft tunnel. What do you guys think?
-B
Injuneer
08-20-2006, 09:34 PM
I have an SX fuel filter, and while its only about 8" long, I managed to mount it in the stock location. Braided lines from the tank to the filter follow the stock routing, although the inlet and outlet ends of the filter are swapped. Then the lines run forward and up under the firewall to the back of the engine, splitting in a "Y" to the back of each fuel rail. The return comes off the diagonal cross-over pipe in the front of the rails, to a Weldon AFPR under the cowl, then back down under the firewall, returning to the tank following the stock routing.
http://www.injuneer.com/images/photos/Suspension/DCP04302a.jpg
