11 sec. Impala SS for sale
This Impala SS is #2 on the current national ET times N/A....
It is street driven and gets 19-21mpg on the highway
400 rwhp n/a 480 w/ n20
It has 124, xxx original highway miles. The car is like brand new inside and out.
Engine mods:
Stock lower end with 80k
Melling HV/HP oil pump
AFR 210 LT4 CNC heads, ARP head bolts,and rocker studs.
Ported intake
BBK ported and polished 58mm tb
Comp r lifers
racetronix fuel pump and harness
30# SVO injectors
LT4 KM
Taylor ignition wires over the valve covers.
Accel 300+ ignition and coil
Custom ground comp cam 230/236 .570/.576 112ls
Comp magnum roller rockers and pushrods
Polished aluminum valve covers
Mallory billet Aluminum high polished:
p/s cap, brake master cover, tb plate, w/p plate, fuse box plate, coolant cap, alt. pulley, a/c pulley, p/s pulley, MAP cover, oil cap, radiator shroud.
Custom painted fuel rail covers W/ Impala SS script
K&N intake with polished alum. Tube replacing the plastic tube
Exhaust:
Clearimage quad-1 headers
Hooker cat-back w/corsa tips
H-pipe
Electric cutouts
Wheels/brakes:
American Racing TT2 17x9.5 wheels
BFG gforce 285/35 r17 front tires
Kuhmo ectsa MX 285/35 r17 rear tires
Drilled and slotted rotors all around
Stealth bolt mod
Rearend:
Eaton posi, GM 3.73 gears, new bearings
Transmission:
built with high alto red clutches raybestos Z-pack,and High energy Kevlar band, monster sun shell,
Transgo shift kit and many more parts
tuning done by LT1 edit.
Suspension:
BMR rear lower control arms, rear sway bar, F-body front sway bar. Monroe severe duty front shocks, stock Decarbon rear shocks. New body bushings and cushions all around, new front suspension bushings OEM.
New OEM front ball joints
Interior:
Customized two tone front and rear leather seats
Brand new carpet
Impala SS embroidered mats front and rear
Camaro leather steering wheel with operating controls
Clear coated bezels
A-pillar gauges (3) tach, Trans temp and oil psi
Exterior:
Custom Impala SS side scripts painted into it on the rear 1/4 panels and rear bumper.
Billet front grille.
New paint all around.
NOS nitrous kit with purge, heater, and remote opener.
Billet aluminum bottle brackets
MSD digital window switch.
The car is like new inside and out! It won 1st in the ISSCA nats in Pocono and many other 1st place trophies.
It has run a best of 11.99 all motor and I haven’t run it with the nitrous.
The car is garaged hasn’t been driven in the rain in years.
Here are some pics
http://community.webshots.com/album/56958899EeKvDg
i have over 20k in this car!
I am asking $13,000 obo neg.
Engine mods:
Ported intake
Comp r lifers
30# SVO injectors
LT4 KM
Exhaust:
H-pipe
Electric cutouts
Wheels/brakes:
Stealth bolt mod
Rearend:
Transmission:
Suspension:
Interior:
Brand new carpet
Clear coated bezels
Exterior:
Here are some pics
guionM
13
Sep 5, 2002 09:58 PM
