1BAD-SS
08-16-2006, 05:23 PM
I have my car posted in the for sale section. Just letting any people in the midwest know to check it out.
Thanks,
Craig
Thanks,
Craig
97 Street/Strip SS in St. Louis1BAD-SS 08-16-2006, 05:23 PM I have my car posted in the for sale section. Just letting any people in the midwest know to check it out. Thanks, Craig 1BAD-SS 08-24-2006, 01:11 PM 1997 Camaro SS #1911 Sebring Silver Metallic Graphite Leather Interior 28,000 miles on car 396 Cubic Inch LT1 (Less than 4,000 miles on motor, less than 1,000 miles since freshened up) Forged 3.875” Callies Crank, Forged 5.85” Lunati Rods, Forged JE Pistons (12.1 Compression Ratio) 4 bolt billet splayed mains ARP Head Studs Canton Oil Pan BBK 58MM TB Delphi 42lb/hr injectors Racetronix Fuel Pump and Harness Aeromotive FI Regulator Meizer Electric Water Pump Mallory Hyfire 6 Ignition (built in two-step and window switch) Accel Extreme 9000 wires over the valve covers Hooker Super Comp Coated Headers Mufflex Y-pipe 4 inch Dynomax Bullet Muffler dumped at axle 95 OBD-1 PCM Tuned by Speed Inc. (LT1 Edit Software and Computer Included) Custom Billet Solid Roller Cam by Brett Bauer Comp HiTech Lifters Comp HiTech Stainless Rockers (1.7 Intake, 1.6 Exhaust) Comp 7/16 Pushrods Cloyes Double Roller Timing Chain Ported LT1 Castings 2.0 Intake and 1.56 Exhaust Valves Manley Race Flow Valves Comp HiTech Valve Springs for Solid Roller Cam Comp Titanium Retainers (Less than 1,000 miles since freshened up (more porting, new valve seals, etc)) Intake matched to heads NOS Sportsman Direct Port Fogger Dedicated 1 Gallon Fuel Cell Dedicated Aeromotive Pump and Regulator All Stainless Braided Fuel Lines NOS Digital Progressive Nitrous Controller AOD Hybrid Tranny (installed May 06 with about 80 miles on the clock) Built by CK Performance with Transbrake and JW Ultrabell (This trans will hold over 900HP in a 3,700 lb. car no problem) Pro Torque 3,500 Convertor B&M Flexplate and Tranny Cooler B&M Quick Silver Shifter with button on shift knob Dynatech Chrome Molly Driveshaft (Billet 1350 Slip Yoke and 1350 U-Joints) Line Lock and Summit Proportioning Valve Moser 12-Bolt Rear End (3,000 miles) 4.10 Gears Eaton Posi 33 Spline Axles Weld Draglites 15x3.5 front 15x10 rear Sportsman Front Runners 28x11 ET Streets and 275x60 ET Drag Radials (5 races) Custom Chrome Molly 8-Point Cage and KB Double Diamond Sub-Frame Connectors BMR Tubular K-Member QA-1 R-Series Front Shocks and Springs Sphon Lower Control Arms Sphon Adjustable Torque Arm with DS Safety Loop Hotchkis Strut Tower Brace This car is in great shape. I picked it up new from the dealership in March of 97. The car currently doesn’t have the heat or AC in it (still have everything off of car except the AC compressor). Will include all stock parts wanted. Garaged and covered from day one and has only seen rain 3 or 4 times. Car runs 6.30’s in the eighth at 115mph all day long on a 225-250 hit running 110 octane on drag radials. Motor was tuned conservatively on pump gas and set for open loop with a 12.5 AFR. Nitrous has been used on a conservative tune also. If leaned on, 6-teens in the 1/8 should be no problem (mid 9’s in the quarter). This car is a great street car too. Never runs hot. The new overdrive combination really adds to the street manners of this car. Overdrive is great! If needed, some sort of arrangement can be made to prove this car’s performance. Will include two 10 pound bottles, LT1 Edit Software and Laptop, and anything else I have for the car. Perfect ready to drag street car. Asking $16,500 Please call or email me with any reasonable offers or inquiries. craigchadbourne@charter.net 314-712-5751 Nick_dub 09-01-2006, 07:30 PM BUMP SOMEONE SHOULD BE ALL OVER THIS!!! PERFECT CAR whats up Craig? long time no see. 1BAD-SS 09-03-2006, 07:12 PM Hey Nick. I have been up to the same old stuff (all work and no play)! You still working down South of Barnhart? Nick_dub 09-04-2006, 04:17 AM Hey Nick. I have been up to the same old stuff (all work and no play)! You still working down South of Barnhart? i hear ya on the working...im at the lemay store now stop by when you can!! 1BAD-SS 09-23-2006, 01:51 PM The car sold on ebay, but the bidder cannot come up with the money. That's my luck these days. The car is still for sale. Thanks, Craig | ||
