100or150 shot
Old Aug 15, 2006 | 05:29 PM
mikegravley's Avatar
100or150 shot
will a stock ls1 still stay relable with a 100 or 150 shot and what would i need besides the nitrous
Old Aug 15, 2006 | 09:04 PM
camzaro28's Avatar
Re: 100or150 shot
search forum, is what you couldve done. all noobs make mistakes, no worries, lol
FPSS, mallory 685, purge, ngk tr6 plugs, bottle warmer. i think that is it.
Old Aug 16, 2006 | 12:00 AM
LT1Mike's Avatar
Re: 100or150 shot
no racetronix fuel pump?
Old Aug 16, 2006 | 09:12 AM
HarrisSpeedWorks's Avatar
Re: 100or150 shot
Is the car stock? If not what is all done to it?
Matt
Old Aug 16, 2006 | 12:56 PM
LT1Mike's Avatar
Re: 100or150 shot
I'm doing everything he said, including a racetronix kit with my mods below... 100shot also.
Old Aug 16, 2006 | 01:44 PM
Grims's Avatar
Re: 100or150 shot
It can take a 150 fine.
Old Aug 16, 2006 | 05:38 PM
2000GTP's Avatar
Re: 100or150 shot
Reliability will depend on how you have your system setup. If you don't cut corners and run all of the safety gear as mentioned above, you should be able to run a 150 shot without any problems.
Old Aug 16, 2006 | 08:51 PM
Grims's Avatar
Re: 100or150 shot
I have been running a 150 shot with the above saftey equipment on a 150 thousand mile motor about 3 dozen times.
Old Aug 17, 2006 | 01:15 PM
LT1Mike's Avatar
Re: 100or150 shot
what about running a 75 shot? still think all the necessary parts are needed? or just the kit, a window switch and some plugs?
Old Aug 17, 2006 | 01:46 PM
Grims's Avatar
Re: 100or150 shot
Just run it rich no matter how you do it. I ran a 150 shot for around a year with no saftey equipment at all...just have to be careful with your shifts, and run it rich.
Old Aug 17, 2006 | 01:54 PM
LT1Mike's Avatar
Re: 100or150 shot
hmmm... i would prefer.... just like a 75 shot, mallory 685, cold plugs.. and thats it.. and buy the rest in pieces and double the shot..
Old Aug 18, 2006 | 12:06 AM
LT1Mike's Avatar
Re: 100or150 shot
what do you guys think? 75 shot... with a window switch, and plugs.. then get the heater, purge, fpss, and racetronix?
Old Aug 18, 2006 | 01:59 AM
93Phoenix's Avatar
Re: 100or150 shot
Whats fpss?
Old Aug 18, 2006 | 02:13 AM
LT1Mike's Avatar
Re: 100or150 shot
Originally Posted by 93Phoenix
Whats fpss?
Fuel Pressure Saftey Switch...
I'm in the middle of saving up for gears/spray... should be like one month and then ill have enough... I'm highly considering a Hotcam kit... But i'm not sure...
Old Aug 18, 2006 | 09:26 AM
Re: 100or150 shot
You could run a larger shot then that with the Racetronix pump if you wanted to.
Matt
