Pecos Pete
08-15-2006, 01:09 PM
What I am looking for is someone that has experience or information building a LSx, LS1, Gen III that's purpose built to run E85. Purpose built to run 105 octane alcohol (ethonol) ONLY. I am not looking to include the Flexfuel feature, just run E85 all the time. That's the important thing. An engine that's built to run alcohol can scream, but it has to be optimized for the fuel. Larger injectors, timing, higher compression, maybe even the camshaft should be set up to take advantage of the cooler burn and increased octane. Basically this stuff is just alcohol with enough gasoline thrown in for cold starts. It is racing gas.
www.hybridcars.com/blogs/hyview/more-from-ethanol
The ECM programming will take some effort to get right. I know this. I understand alcohol burns at a different rate than gasoline, so the timing will be different. I also understand that the cylinder pressure from Alcohol lasts longer so a larger rod/stroke ratio will help exploite this. I also undertstand alcohol also burns cooler than gasoline, so it takes longer to light off the catalytic converters. O2 readings will likely be different. Wide band O2's may be necessary. Making it E85 specific simplifies things a bunch, but this will also be breaking new ground in uncharted terratory.
I am just looking for a straight forward combination of LSx parts to achieve at least a 14.5:1 compression ratio so I can get busy shaking out the computer reprogramming changes.
If I use a;
6.0 block => 101.6mm bore (4.000")
6.0 flat top pistons
4.8 crank => 83 mm stroke (3.268")
4.8 rods => 159.38 mm (6.275")
LS6 heads => 61cc
.040 head gasket height
I end up with a rod/stroke ratio of 1.92:1, a calculated static compression ratio of 11.98:1, and a calculated lower piston speed due to the short stroke that will allow 7500 to 8000 rpms on stock length 4.8 rods.
www.race-cars.net/calculators/compression_calculator.html]
What works best to get the compression up even higher? How much can the heads be milled? I know flat top pistons are best for flame propagation, but are domed 6.0 pistons available?
Anyone done something like this yet?
I want to end up with something like Westech's 302 motor, but optomized for E85.
http://www.camaroz28.com/articles/302camaro/index.shtml
If I use a;
LS6 heads => 61cc
