would i need a better amp??
Meatyshells
08-07-2006, 05:56 AM
i am looking to buy 2 of these (1 for each stealth box)
http://www.crutchfield.com/S-DfyGlLlx4ak/cgi-bin/ProdView.asp?g=520&I=500SWS1042
and i was wondering if the amp i have now would be enough to power both of them? http://www.crutchfield.com/S-DfyGlLlx4ak/cgi-bin/ProdView.asp?i=113KAC6202
Klypto
08-07-2006, 06:15 AM
dude...
alot more power... you want 3-400 rms.... id go 450-500 and lower it a little...
kicker 400.1 a badass lil amp thats cheap
cory
Meatyshells
08-07-2006, 06:33 AM
this the one you are talking about?
http://www.crutchfield.com/S-2n6FETBbsW8/cgi-bin/ProdView.asp?g=120&I=206ZX4001
Klypto
08-07-2006, 05:49 PM
yea, put it at 2 ohm and your good to go
Meatyshells
08-07-2006, 07:22 PM
do you think i would need a cap if i ran with both those alpines and that amp?
Šenial™
08-07-2006, 10:17 PM
You dont need an amp to match up exactly with the rms of your subs, 50 or so lower is just fine, rms is the ammount of continuious power it can provide, yes.. but not all the time are you going to be going around with your stero turned all the way up needing all that power rms and peak is basicly just a selling point for amps and subs, people usualy think the bigger the better of course.. but its not and you wont need it.
Now, if you do have a bit of extra coin to spend, the sure get a bigger amp so if you ever do decide to get some bigger subs you wont need to upgrade the amp also, just turn down the gain low enough if it is a more powerful amp so you dont get that anoyying sound of wires hitting the basket all the time and then blowing your subs, i used a 4,500 rms amp to power my single little kicker for the longest time until i got around to getting my 2 adire brahmas
Meatyshells
08-10-2006, 02:55 AM
is this is the same amp that is mentioned above? im not sure if i want to buy it cause it seems like its to cheap
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=019&item=290017231226&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
valter
08-10-2006, 01:45 PM
You probably want to hear them before buying. I tried Kicker, JL (500/1), Hifonics (Brutus) amps for my sub, but ended up with Rockford Fosgate monoblock, which produces the sound I like. All sounded different.
Mr. 350
08-15-2006, 10:50 PM
go for a zapco. a 500.1 will give clean, consistent, reliable power. it will last you forever. a little expensive but it will be worth it. I gave one to my best friend and he has been smiling ever since.
Robs97Z28
08-18-2006, 09:44 PM
JL audio is the way to go.. run a 10w3 or an older 10w6 in a JL audio stealth box. this setup hits very hard and will make the hatch vibrate! The one amp can run the while system... if you can find one, I would use an old PPI amp PCx480 and use the Q-bass to control the sub.
http://acaraudio.com/product_info.php?manufacturers_id=14&products_id=167
http://acaraudio.com/product_info.php?products_id=184
http://mobile.jlaudio.com/products_stealthbox_make.php?make_id=47&model_id=174
rowdyrebel_2004
08-25-2006, 01:18 AM
i personally would go with a rockford fosgate punch 600.1 class bd amp sure its a lil expensive but to me its worth every cent.
