when to replace tie rods??
Old Aug 5, 2006 | 09:48 PM
touch109's Avatar
Question when to replace tie rods??
I just recently installed my slp eibach/bilstien combo.. but the guy who was going to do my alignment said the tierods were going bad... he should me under the lift that tie rod bar moved very lil... haven't really had any problems steering a lil loose but i do hear a squeal when i turn the wheel all the way..... if i do what do i need...
Old Aug 6, 2006 | 06:37 AM
RE AND CHERYL's Avatar
Re: when to replace tie rods??
If there is play in them, they need replaced.
I would assume the squeal you hear ar full lock is the P/S pump belt slipping.
Old Aug 6, 2006 | 01:54 PM
OBE1 95Z28's Avatar
Tie rod ends aren't very expensive and are a wear item over time.
Jun 6, 2015 08:27 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
