wheel well + floor pan rust repair
Old Aug 1, 2006 | 11:03 AM
Camaro_Boy's Avatar
hey guys, inside the rear wheel well.. right in the corner there is a hole the side of your rist. i want this fixed asap. best route to go? sandblast it and then cut the rust out and then put new metal in and weld or is there a better way to fix this. when this car is done the car will not be drivien in the winter.
the floorpan has a fist size hole as well. is it best for me to cut the rust out and weld in a piece of metal and then undercoat? thanks so much
i want to do things properly and not have to worry about them when done
best regards
Douglas
Old Oct 20, 2006 | 10:59 AM
green.Z's Avatar
Re: wheel well + floor pan rust repair
A little late in response, but I just found this under a search for "rust".
I have the same problem with my car in the wheel wells. I had it repaired with weld repair patches and some filler 2 years ago. It is now back to rust again with holes. If you want it done right, get new panels. I drive mine year round though.
Old Oct 20, 2006 | 02:47 PM
2000GTP's Avatar
I agree with the above poster, rust is like cancer of your car. Once it starts, it is very difficult to reverse. All new panels is usually the best repair. Sometimes you can get away with completely cutting out the rusted area and welding in a new piece of metal.
Old Oct 20, 2006 | 06:44 PM
Blue89Bird's Avatar
You can safely cut out the rusted areas and weld in a new replacement panel. If you do it right, it wont come back. Doing it right means removing it all, using seem sealer on all seams, and then priming and painting with rust preventative paint, such as POR15
Old Oct 20, 2006 | 08:29 PM
oneslowz28's Avatar
Post number 4 in my body work write up may be helpful. The write up can be found here http://web.camaross.com/forums/showthread.php?t=470536
mattstrike
Mar 11, 2015 07:33 PM
dale3in98
Feb 14, 2015 12:18 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jason Short
Jan 19, 2015 06:33 PM
Sandersen511
Jan 13, 2015 03:49 PM
