VE dimensions-could be clue to actual 5th gen dimensions
91_z28_4me
07-24-2006, 08:09 AM
From GMInsidenews (http://www.gminsidenews.com/forums/showthread.php?t=34309):
All dimensions are the SWB VE.
Overall length
4894 mm = 192.7 inches
Wheelbase
2915 mm = 114.7 inches
Height
1476 mm = 58.1 inches
Width (excluding mirrors)
1899 mm = 74.7 inches
Base engine specs
3.6L V6, peak power 180kW, peak torque 330Nm, four-speed automatic
246.6 hp
Also has a midlevel High output V6
3.6L V6, peak power 195kW, peak torque 340Nm, six-speed manual or optional five-speed automatic with Active Select
267.15 hp
Base V8
Optional 6.0L V8, peak power 270kW, peak torque 530Nm, six-speed automatic
369.9 hp
Z28Wilson
07-24-2006, 01:31 PM
Too big to be the new Camaro. At least, I hope it won't grow 6 inches in length compared to the concept....192" is within a sliver of 4th Gen size.
FS3800
07-24-2006, 01:52 PM
the new global RWD platform (zeta) is pretty flexible.. allowing for different cowl to axle distances, different wheelbases, lengths, widths.. the stats for the VE here mean nothing in relation to the Camaro..
91_z28_4me
07-24-2006, 02:37 PM
I bet it does mean something. Body Width will be right at that. The width at the wheels may be different but I bet the door to door width is almost exactly the same.
Dan Baldwin
07-27-2006, 09:56 AM
But does it allow for racically shorter cowl HEIGHT?
With a height of 58", I'm afraid this car will be TOO FRICKING BIG.
sselie
07-27-2006, 10:38 AM
I believe there is a fair amount of flexibility with respect to the cowl height... one of the huge advantages built into the design of this platform.
A radically shorter cowl height? I'm just not sure how to quantify "radically".
Best regardSS,
Elie
Dan Baldwin
07-27-2006, 04:38 PM
Radically = maybe 4" - 6". It'd be nice to have the height under 52", not have the greenhouse too pinched, and not have the fenders too high.
Ray86IROC
07-27-2006, 07:50 PM
What's it weigh w/ the V8, is that spec out? Just curious, not that it would mean anything for the weight of the Camaro other than perhaps a maximum ceiling...
305fan
07-30-2006, 09:34 AM
lets pray its not 58" tall and 114" wheelbase!!! ugh...thats longer then a Equinox!
guionM
07-31-2006, 01:47 AM
the only thing on the VE that's going to carry over to Camaro according to those I talk to are the front and rear suspension assemblies and a few ideas used on the VE (such as a front section that bolts in instead of being welded on that contains the radiator support, etc...).
