Would a 155 speedo work on a 2001 v6 camaro
GusarskiSS
07-24-2006, 12:53 AM
I have a 155 speedo from a 99' Z28. Would it work putting it in a 01' V6 Camaro? Does anyone know how the 155 speedo can be converted to metric?
Klypto
07-24-2006, 02:07 AM
i dont think its an easy swap
GusarskiSS
07-24-2006, 03:40 AM
I'm talking about the whole cluster you know? Not just an overlay.
Fierotom
07-24-2006, 11:56 AM
Caution!
When installing a new I/P cluster (on the last 4th gen's) it must be synchronized to the SIR module!
You need a TECH2 ScanTool for this!
I can give you the exact procedure if you need
jonathan_abilene
07-24-2006, 05:39 PM
i dont know anything, but i think you'd need a 155 mph speed sensor as well
GusarskiSS
07-24-2006, 08:21 PM
What do you mean it has to be synchronized to the SIR module? How and why? And are the sensors different?
gmanss
08-06-2006, 10:27 AM
I would not put a 155 on a v6 car. It would take to long to get there, if it can get there. if you want it for looks than its cool.
wakebordr2006
08-06-2006, 12:04 PM
i put one in my 95 v6 camaro and it works just fine
VladimirSteel
08-06-2006, 01:02 PM
ive heard that everything will work besides the tach, since the tach on the 155 speedo reads for 8 cylinders instead of 6, so it will read lower or higher.
zero231
08-07-2006, 08:45 PM
you have to get one from the exact same year...if you have a 99, you need to get one from a 99 z28.
I did this swap in my 97 RS...everything works, except the tach which reads low...this can be fixed with a tach adapter from dakota digital. "sgi-8" or something.
99blackSS
08-11-2006, 08:18 AM
I don't know about the early 4th gens (93-97) but from the posts it sounds like just the tach will be off.
On the late 4th gens (98-02) I know the speed would at least be off.
rt1
08-11-2006, 01:38 PM
Check out this from camarov6.com (http://forum.camarov6.com/showthread.php?t=69799). I think what "Antman" typed is true. The early 4th Gens have a tach problem, well mine anyway, the later ones shouldn't.
Rob
