Wishmaster
07-19-2006, 01:10 PM
how many freaking O2's does this car have? my SES light is on and I had it scanned at AZ...and the code was for "downstream O2 sensor bad"
which one is that? how many do I hae?
thanks
Fierotom
07-19-2006, 02:16 PM
The 1997 V6 engine has 4 sensors!
one in each "header", one before and one after the cat......
but downstream O2 sensor bad????
I think it is the one befor the cat, but I'm not 100% sure.
have you the original error code? It's like P01xx .....
Wishmaster
07-19-2006, 03:11 PM
4!!!!!...holly crap!!!!!!..and they are like $60 a piece!....damn this car!
I dont remember what the error code was..I guess I could go back and have them do it again.....they didnt know which 02 it was either....
valter
07-19-2006, 03:50 PM
"downstream" should be after-cat sensor. It isn't affecting anything at all - it's for emissions control only. You may disregard this code :D If you will be changing it, go with delcos, bosch sucks.
Don350k
07-19-2006, 07:42 PM
Or you can do what i did buy a simulator and knock the cat out =-)
Bones
P.S. you can keep the cat on also but a sumulator is around $20 alot cheaper that a 02 sensor and there easy to install anyone who understands a volt-meter can
AlfredB18
07-20-2006, 01:21 AM
Likely, the O2 sensor is not bad, but you have some other issue going on that is causing a lean or rich sensor reading to appear--of which many causes there are for such events. More often than not, O2's get replaced....because people like tossing money at parts, I suppose.
Of course, no code = no help in any case.
jonathan_abilene
07-20-2006, 03:56 AM
you only need 2 of em on your car
my car only needs 1 sensor and that is a wideband sensor
Wishmaster
07-21-2006, 09:39 AM
well I took it back to AZ...then I wrote down the code but forgot it ....its on a piece of paper...anyways, it said (bank 1 sensor 2)....I had the guy clear the code for me...and told him i would buy the sensor later since it was $70
the SES light has not come on since!....beats me!!....
