97 z28 with ls2
Re: 97 z28 with ls2
You're much better off doing a heads/cam/stroker setup to get the desired power than trying to force the LS2 into your car.
Unless you have nothing but time and money - then by all means.
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: 97 z28 with ls2
yes pandamonkey is correct.. i'll break it down barney style for you.
you are sitting on your couch craving a chocolatey treat.
you can:
A. Plant a cocoa tree seedling in your backyard and wait
B. take the 1/2 mile drive to the exxon and get a crunch bar
option B provides better results in a shorter period of time with less effort, and money.
hope that helps
Jared
you can:
hope that helps
Jared
Re: 97 z28 with ls2
you can:
hope that helps
Jared
you can:
hope that helps
Jared
ive never heard it put that way before...
Re: 97 z28 with ls2
As mentioned by the above posters, the transplant would be costly and time consuming just like any swap. But on the flip side, if you have the money and time, it would definitely be a different, more unique approach.
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
