water tank dimensions???
bowtiepwr
07-16-2006, 09:09 AM
>so what size water tank are you using for your intercooler? and where did you install it? I want to use the Jegs 5 gallon tank
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=19797&searchItemId=72971
any suggestions?
bowtiepwr
07-17-2006, 08:52 PM
any suggestions?
>so I ordered the 3 gallon instead... probably a mistake and will order the 5 gallon when the 3 gallon gets here :think:
JZ 97 SS 1500
07-18-2006, 12:59 AM
3 gallons is enough, and make sure to use a heat exchanger if you plan to daily drive it.
JZ
bowtiepwr
07-18-2006, 08:07 AM
JZ
>I ordered B&M Hi-Tek Cooling System 130-70298 from Jegs...
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=21061&searchItemId=71671
JZ 97 SS 1500
07-18-2006, 10:37 AM
That will work perfect. Its the same unit I'm using.
