Where can I find Mini-Cats / Bullet Cats?
I am going with a Long Tube Setup and I need to know where to find Cats small enough to clear the underside of the car. Can you throw a link up or something? Thanks...
Re: Where can I find Mini-Cats / Bullet Cats?
Check out the flow chart from installuniverstiy.com. Bullet cats aren't much better than stock:
Table 1
Inlet Diameter (in.)
Outlet Diameter (in.)
CFM @ 20.4” H2O
CFM @ 28” H2O
Passenger Side Catalytic Converter
2.5
2.5
299.5
350.9
Driver's Side Catalytic Converter
2.5
2.5
268.3
314.4
TTS Bullet Catalytic Converter
2.5
2.5
277.1
324.6
Carsound Catalytic Converter
2.5
2.5
372.7
436.7
FLP Catalytic Converter
2.5
2.5
376.0
440.5
Just get some short carsound cats. Plus the flat top and bottomed converters will give you more ground clearance than the round bullet types.
Table 1
CFM @ 20.4” H2O
CFM @ 28” H2O
2.5
2.5
299.5
350.9
2.5
2.5
268.3
314.4
2.5
2.5
277.1
324.6
2.5
2.5
372.7
436.7
2.5
2.5
376.0
440.5
Originally Posted by Zitty'sZ
Just buy a catted y-pipe from Texas Speed, it's adjustable, the cats are small and it takes some of the rasp out the exhaust.
Originally Posted by Need4Camaro
Well the problem is, I'm going with true duals. Besides would a Catted Y-Pipe fit on long tube headers correctly?
Can I get Carsounds webaddress?
Originally Posted by 2000GTP
Their are several catted y-pipes for the LS1 long tubes. The hard part is finding a catted y-pipe for LT1 long tubes.
Can I get a Catted Y-Pipe, have it cut at the end and have an X-Pipe wielded at the end of the Y-Pipe and run my true duals from the X-Pipe?
alex5366
Mar 8, 2015 11:32 AM
Dec 1, 2014 08:08 AM
