ghost stripes
07-04-2006, 08:03 PM
how do you wire the line lock up does the post on the cylinder has a positive and negative ....when installed does the linelocks disable the brakes on the rear or lock the brakes on the front?...any pics of installation will be appreciated
MyShibbyZ28
07-04-2006, 09:07 PM
I believe it just locks the front up, and keeps the back open yet still functional.
Injuneer
07-05-2006, 10:49 AM
Red wire will be +12V, black wire will be ground.
The solenoid get installed in the line for the front brakes, running from the master cylinder to the distribution block on the side of the ABS unit. The front brake line is the one that starts from the rear of the master cylinder. When you put your foot on the brake, actuate the solenoid, and lift off the brake pedal, pressure is held in the front brake lines.
http://www.injuneer.com/images/photos/Brakes/LineLok.jpg
"White Knight"
07-07-2006, 11:38 AM
I believe the SLP unit has both gray wires for + and -. I don't have any pictures of mine on hand. The wires can go either way as long as you have one on + and one on -.
