C5 caliper + LS1 f-body rotors: Will 16" salad spinners fit?
RichJ
07-04-2006, 07:26 AM
Does anyone know whether this combo will work? Thanks.
94CamaroZ28
07-04-2006, 03:47 PM
Don't think so, I think you'll need 17s, or have to grind a LOT off the calipers to get salad shooter to fit.
OBE1 95Z28
07-04-2006, 05:16 PM
It won't fit. The C5 calipers won't clear my Enkei 17" Winn wheels. I ended up with the Baer 13" Track Kit that barely clears.
gt_biker13
07-04-2006, 09:05 PM
Hes not talking about the whole C5 kit. I used LS1 calipers and rotors in my salad shooters and they fit. But im not sure if the C5 calipers are larger or not.
RE AND CHERYL
07-04-2006, 09:18 PM
I wouldn't waste my time with that set-up. Although the pressure cast C5 calipers are stronger than the LS1 calipers, your not gonna notice any difference in braking with them.
respectirocz
07-05-2006, 10:19 AM
the ls1 calipers and c5 calipers are dimensionally the same i believe so you should be able to use c5 calipers with ls1 brakes inside 16in salad shooters
94SLUG
07-05-2006, 05:26 PM
Im about to the the c5 upgrade myself. The entire c5 system will not work on 16 salad?
gt_biker13
07-05-2006, 11:53 PM
The C5 rotors will not fit inside any 16 wheel. It needs at lest 17s and i heard that some 17s dont fit.
nfa
07-06-2006, 06:47 AM
Its not the fact that they calipers are dimensionally larger that will be the problem. The adapter brackets that are necessary to install the C5 calipers are positioned in such a way that they are barely fit inside of my 17" SS wheels. I cant see how they would fit inside a 16" wheel.
