96ZCamaro
07-01-2006, 11:26 AM
Do I have to go to the dealer to get the rear end additive or can I get some additive from a local parts store when changing the rear end fluid?
GM Limited slip additive96ZCamaro 07-01-2006, 11:26 AM Do I have to go to the dealer to get the rear end additive or can I get some additive from a local parts store when changing the rear end fluid? n2ceptor 07-01-2006, 11:36 AM Local part stores usually have limited slip additive... It might not be GM, but it works...:) BLK96Z28 07-01-2006, 07:52 PM I believe NAPA carries actual GM additive. matLT1 07-01-2006, 10:05 PM I got mine from Autobone. It should say on the tube that it is equivalent to GM additive. Capn Pete 07-01-2006, 10:45 PM Just curious, but is there a reason you don't want the GM additive?:shrug: Is there a better additive out there, or is it the cost? I mean, I think it's only ~$7 CDN$ a bottle, and you only need 1 bottle, right?:think: 96ZCamaro 07-02-2006, 08:54 PM No I was just wondering if I would have to go to the dealership or not to get it. It's kinda a pain to deal with the guys at dealerships and wanted to avoid it. shoebox 07-02-2006, 10:38 PM The GM additive will work, while other brands may not. Don't know why this is so, but it sure is a hassle to have to go back to put in the GM stuff when the other does not work. I just buy the GM stuff the first time. 96ZCamaro 07-03-2006, 10:41 AM Alright, well I'll probly go up and try napa first to see if they got it. If they dont I guess it is off to the stealership. | ||
