rear springs with mini tub
noregretz999
07-01-2006, 04:54 AM
I was looking at this mini tub kit from wolfe race craft for my 95 camaro
http://www.wolferacecraft.com/SearchResult.aspx?CategoryID=180
I was going to also get the adjustable upper spring mount and 150 lb rate springs which are options for the kit but was questioning those springs that are included. Is this a correct spring rate, for a car that will be mainly used for drag racing, but occasionally driven on the street? I am using the gen f HAL shocks all around. With this mini tub kit, can I just use stock rear springs, or will I need a smaller diamater spring? I know I should talk to wolferacecraft directly, but it has been hard to get in contact with them, so I figured I would try this site out.
thanks for and info or suggestions
94CamaroZ28
07-02-2006, 12:16 AM
Hmmm... too hard to get in touch for pre-sale tech support is not a way to get MY business... especially for anything as critical as suspension. Try getting in touch with S&W...
1970z28
07-02-2006, 12:31 PM
dont have an answer to your question but i like the mini tub.
noregretz999
07-03-2006, 04:00 AM
thanks a lot for the reply paul...ill try them out
noregretz999
07-05-2006, 09:38 PM
I got in touch with wolfe, and yes, the 150 lb springs are what most people are using at this time, with good results.
