700r4 conversion question
94_camm
06-28-2006, 04:57 PM
Ok iam doing the 700r4 conversion to my 94z with 4l60e.i have been doing some research and found some stuff need and some stuff i still have questions on.now do you need to get your computer tuned or no?were does the tv cable go on the trans?will the 4l60e driveshaft/torque arm fit on this?
Stuff Need:
-tv cable
-That lock up button thing
-4l60e speed sensor to but on the 700r4 trans
Am i missing anything else?
12SCNDZ
06-28-2006, 09:33 PM
You'll need a '93 throttle body. Your '94 style doesn't have a place to attatch the TV cable. You'll want to buy a new TV cable for a 1993 LT1 camaro. I'd also suggest buying a governor for your 700 that is for a 1993 Camaro
The computer will not control anything in the 700, if the TCC is wired correctly, internally. You can splice into your current TCC wires that ran to the 4L60E (Hot and ground). If you wire it correctly, you won't need an external lock up switch. You can make lock-up come in after 4th gear, by wiring the transmission correctly.
The TV cable bolts to the passenger side of the transmission, just behind the servo cover.
Driveshaft and torque arms will fit as long as it's a 2WD 700R4. You can use the 4L60E tailhousing on the 700.
Frank
CPT
94_camm
06-28-2006, 11:48 PM
thanks
louvit
07-15-2006, 01:53 PM
I have a 93 z with a 700 and the speedo don't work..its not plugged in and I cant find the outlet on the trans...any ideas?
Dave89IROC
07-16-2006, 12:05 PM
it should plug into the speed sensor on the drivers side of the tail shaft
louvit
07-16-2006, 12:16 PM
thanks I'll give it a looksee..
louvit
07-22-2006, 03:14 PM
the plug has 5 prongs and the socket has 4 on the trans...any idea's?
Dave89IROC
07-22-2006, 03:23 PM
thats not the VSS plug
the plug for the VSS is a two pin that connects to the sensor in the tailshaft(near the driveshaft/trans mount)
and that trans is not fron a 93 camaro, its earlier(93 used the 5 pin connector, earlier ones used the 4 pin)
the 4/5 pin connector is for gear info(3rd gear, 4th gear) and TCC
louvit
07-24-2006, 06:51 AM
ok the 2 pin is plugged in. took out the speed sensor and the plastic gears are stripped...and of course its a dealer item. will get one today I hope. what is vss? is it necessary to be plugged in?
thanks for the info
Dave89IROC
07-24-2006, 07:11 AM
VSS = Vehicle Speed Sensor
louvit
07-24-2006, 08:05 AM
is the vss being unplugged a bad thing?
