Supercharger and BARO
Old Jun 27, 2006 | 05:11 PM
tici's Avatar
To my knowledge the PCM checks the atmosferic pressure at start up (BARO), this using the MAP.
At WOT (I'm not sure if at a certain load or a certain TPS) the BARO value is also updated.
With the supercharger I noticed that the BARO value is updated at partial throttle too, as soon as the intake pressure is higher than the pressure at start up ( I saw that already at 40% TPS), it was still cell 15 and not in PE.
The max pressure that my stock map can see is 104 kPa and as soon I hit that pressure the BARO will have that value.
A normal value is 95 kPa, 104 kPa is about 10% higher.
When the BARO value rises LTFT's go negative (-5% up to -10%).
Is there a way to let the PCM check for BARO only at start up?
When I turn off the car and let it cool down LTFT goes back to the normal values. If restert the car with a warmed up engine the BARO is not updated, but it keeps the last value.
Thanks - Stefano
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
