Out of adjustment on Camber
69gto96z
06-25-2006, 06:26 PM
I lowered my car and took it in to have it re-aligned and they said my camber is out of adjustment and it is still a degree off. Is there anything I can buy to correct this? Like a camber kit or anything?
Injuneer
06-25-2006, 10:30 PM
I've taken the front end down almost 2" and they were still able to align it.
But what specs are you trying to align it to? You don't want to use stock alignment specs on a lowered car (actually, the stock specs aren't all that great for a stock height car). I ran -1deg camber, +4deg caster, 0.10 toe. There are simlar specs in the 4th Gen FAQ for lowered cars:
http://www.f-body.org/faq/4/4_5.htm
Ricardo
06-25-2006, 10:33 PM
You can use a set of adjustable upper A arms from BMR or some other supplier.
One degree off is not that bad at all. I suppose you are talking negative camber.
You could also remove the lower A Arm completely and make the slot longer on the K Member to gain a little more adjustment
RG
