RACEON
06-25-2006, 04:25 AM
I recently had installed DENSO 3 wire heated O2 sensors in my LT1 and a DELTEQ, replacing the single wire BOSCH sensors that my tune was done on.
The reason I did this is my 93 LT1 has a LT headers and a medium cam, 230/236 XE in a stroker motor.
The tune was very good before, just the idle was burning my eyes because it wouldnt stay in closed loop. The Heated O2's fixed this.
The dyno before today was 425 rwhp 428 tq with 12.9 AFR and now with the new O2's its running 14 to 1 AFR! and making 396 rwhp and 365 torque.
Also, the second Dyno was different from the original place and the Wideband was placed in the tailpipe of the second run (which had lots of balck smoke) while the first dyno was in the bung right after the collector, but no black smoke.
On the road when I floor it it does the basic black smoke puff intially then there isnt any black cloud.
MY BLMS at WOT are 128 and the O2 sensors are 850( plus or minus 10 points) area at WOT, 36 degrees timing and no knock. FP 43psi with vacuum line disconected.
