Stock heads
Old Jun 24, 2006 | 10:02 AM
mook99TA's Avatar
Stock heads
Are 99 LS1 (not sure of the casting number but I think its 853) worth porting and polishing and putting bigger valves in or not?
Old Jun 24, 2006 | 06:18 PM
GhostZ28's Avatar
Re: Stock heads
Thats what I'm doing right now. I think with a competition port/polish/valve from LS1 casting to LS6 is only a 10-12 hp difference.
The heads 853 and 241 are the same things, just different numbers.
I'm porting a used set of 241's and have them at the machine shop right now doing a valvejob for 2.02/1.60's. After I'm good and done (in a couple more weeks) I'm going to have them flow benched. I'll post pics and results when I'm done of course. Then when i swap them on my car and put in my F13 112 then I'll post my dyno results.
Old Jun 25, 2006 | 02:31 AM
StudyTime's Avatar
Re: Stock heads
The '99 heads are sand cast and the first year for center-bolts. The '01 and '02 cars go semi-permanent mold cast heads that came out better. These are the 241 heads. If they're getting ported, it doesn't matter. Once fully ported there will be no difference. Many do not know this.
Ben T.
Old Jun 25, 2006 | 11:37 AM
mook99TA's Avatar
Re: Stock heads
Ben T.
What do you mean there will be no difference. In performance or between a ported set of 853 and 241's. Or will I be better off with some 5.3l heads ported?
Old Jun 25, 2006 | 07:19 PM
StudyTime's Avatar
Re: Stock heads
853/241 won't be a difference when fully ported. Put all of the other goodies the '01 & '02 LS1 cars got, and there will be a 5hp advantage to the 241 heads. So, basically nothing is gained from ONLY the heads. When both are fully ported, the "slight" advantage is then gone.
862 heads you ask? If they're CNC ported you could do those too. You'll have similar free drop to the heads you currently have, but chambers will be smaller requiring less head milling which would reduce piston-to-valve clearance.
Ben T.
Old Jun 25, 2006 | 07:23 PM
KrazyKamaro's Avatar
Re: Stock heads
What he's saying is that an 853 head is sand cast and that a 241 head is a semi-permanent mold cast.
So you would have slightly better performance out of a 241 head stock as opposed to stock 853 head. Because the insides of an 853 head would be rougher due to using the sand casting technique.
Now if you were to port either head it wouldn’t matter which one you used because, due to the porting all the roughness in an 853 head would be gone.
So if you can find some 853 heads cheaper than 241 heads and you’re going to port them, just get the 853’s and save yourself some money.
Old Jun 25, 2006 | 07:28 PM
StudyTime's Avatar
Re: Stock heads
Bingo.
Ben T.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
