troublesome oil change
Old Nov 9, 2002 | 08:32 PM
SpecForceZ28's Avatar
The bolt that lets you drain the oil is pretty good on there, I bought a vice grip, but no luck. Any tips to unscrew this nicely tighten bolt? Any help is appreciated, this thing is a b****
Old Nov 9, 2002 | 08:35 PM
toykilla's Avatar
OMFG, do Camaro's have some kind of disease that prevents the bolts from coming out as easily as they should?
Old Nov 9, 2002 | 09:18 PM
Camaro ChriSS's Avatar
Are you not using a socket set? Should be a piece of cake (13mm or 15mm, I think). I wouldn't use a set of vice grips... only as an emergancy last resort. They'll strip the head completely.
Old Nov 9, 2002 | 09:44 PM
Capn Pete's Avatar
Arrow
It's a 15mm bolt, and as long as you didn't f### the head of it already with vice-grips, just use a wrench (box end, not open end) and apply lots of force................you can try hooking another box wrench around the open end of the 15mm wrench to use as extra leverage, but as long as you're trying to turn it COUNTER-CLOCKWISE, you should be able to get it out.
BTW: once you do get it out, don't put it in so tight next time.
Old Nov 9, 2002 | 09:56 PM
PhantomTA's Avatar
Moderator
its NOT good to over tighten the plug!
Toykilla, if your goin to be a troll you wont be welcome here
Old Nov 10, 2002 | 02:13 AM
TerrorDome's Avatar
mine came off easy but if it's too tight i'd go to a mechanic i could trust...no sense risking damaging that section
good luck
Old Nov 11, 2002 | 01:04 PM
rncotton's Avatar
15mm Socket always takes mine right off.
15mm box wrench will do it and you can slip a small pipe "cheater bar" over the end for some extra force.
Of course, this assumes that the head is still intact. If the bolt head is screwed, so are you. At that point, you'll have to get creative.
Old Nov 11, 2002 | 01:42 PM
99blackSS's Avatar
I took the pole from the floor jack and put the ratchet handle inside of it to get more leverage. Next time like the other people said the bolt only has to be snug not tight.
Old Nov 11, 2002 | 02:20 PM
birdblack's Avatar
I had trouble with mine also. It was in so tight I started to strip the head with a 12 point socket and box end. I went to Sears and got a 6 point impact socket and it came right out.
SpeedJunkee
Apr 23, 2015 09:51 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
