Where to get ajustable front coilovers
michigan2500hd
06-22-2006, 11:59 AM
Looking to even out the front of the car. Sits low on passengers side by 3/4". Actually the whole front sits too low. Want to raise it about one inch. I have 17" cragars on it now but the rim/ tire combo is within 2 tenths of a inch of stock rim/ tire. Will be trading for stock rims and tires in a couple weeks. Could i just replce the stock DeCarbons and use my springs with a spacer?
Injuneer
06-22-2006, 06:34 PM
BMR makes a 1/2" shim that goes under the bottom of the shock, to space it higher off the lower A-arm.
http://www.bmrfabrication.com/F-bodySuspension.htm
Or, QA1/HAL makes adjustable ride height shocks for the 4th Gens.
http://members.aol.com/InjuneerZZ/images/Photos/shk01.jpg
Might be a better idea to find out why it isn't level. A worn sprnig will still be a worn spring if you use a shim or an adjustable height shock.
michigan2500hd
06-22-2006, 06:42 PM
Might be a better idea to find out why it isn't level. A worn sprnig will still be a worn spring if you use a shim or an adjustable height shock.Yeah i thought about the posability of a weak shock. Think i might order Edelbrocks coilover they make just for the fbodys. It comes complete with the spring and shock. I just removed the drivers side shock and spring a few minutes ago ( did the pass. side last night) so i compared the lower control arms on both sides and it looks like the pass. side is bent slightly. I can see deep gouges and what looks like a little bend outside the front mount. That could be why the pass. side wheel sits 1/2" to the rear of where it should. Maybe?
Injuneer
06-23-2006, 10:20 AM
A bent lower A-arm is a more likely explanation than a worn shock. Shocks don't affect ride height.
michigan2500hd
06-24-2006, 09:24 AM
Yes you are right a shock wont afect ride height unless its stuck. I should have said coilover. I have some edlebrock adjustable coilovers on the way now. Hope they work!
michigan2500hd
06-24-2006, 09:26 AM
A bent lower A-arm is a more likely explanation than a worn shock. Shocks don't affect ride height.I just replaced the pass. side yesterday, it was bent a little and you could see where someone beat the crap out of it trying to straighten it. Why the hell didnt they just replace it? i mean it was only $30. I just hate fixing crap after stupid people.
Honda Hunter
06-25-2006, 02:46 PM
strange, ground control, qa1, afco off the top of my head.
