problem with 2000 Z28 wont go over 20 MPH
tx77015ls1
06-15-2006, 06:22 PM
I was driving at about 70 MPH on the freeway and the car started acting like it was out of gass but I had 1/4 tank. I pulled off to the shoulder and put it in park, it idled fine and reved good so I put it in drive and I had to punch it to get going cuz of traffic but the car just boged down and would not go over 20 MPH i stayed on the gas but it died.
If you ease into the gas, it will go faster but if you floor it it dies.
Any idea? I have it at the dealer hope in covered under my extended waranty
Thanks, jason
Mr_Bond
06-15-2006, 06:33 PM
Almost sounds like the fuel pump went south....
teke184
06-15-2006, 07:05 PM
yeah...i was gonna say fuel pressure
could be the maf too...but if it idles ok...it probably isn't that
2001NBMZ28
06-15-2006, 07:11 PM
Thinking FP too - whatever it is should be covered with an extended warranty. Was the SES light flashing like a Christmas tree?
tx77015ls1
06-15-2006, 07:21 PM
no light at that time. It was on for a while cuz of a O2 but it has gone off and stayed off for a few days.
Could it be a transmission problem or torque converter?
Hope its not the MAF cuz I have those larger blue MAF ends and I dont have the stock ones.
Thanks, Jason
GhostZ28
06-15-2006, 10:05 PM
ya it definately sounds like fuel problem if its acting like its gonna die at higher rpm/speeds
94CamaroZ28
06-15-2006, 11:04 PM
Thanks, Jason
With the O2 having gone south, it could also be a clogged catalytic converter.
ocshaman
06-16-2006, 05:52 AM
When did you change the fuel filter. Could be that your fuel filter is not flowing enough to get you up to a good speed. Was the o2 code for the front or rear o2s?
AL SS590 M6
06-16-2006, 08:54 AM
If we were betting that's where my money would go. That's exactly how a car with broken catyalist will act and if that's it and it has under 80k miles on it, it will be covered by the emmisions warrantee not your extended warantee.
tx77015ls1
06-16-2006, 01:54 PM
Just got a call from the dealer. It was a dirty MAF sensor.
That and my trans mount was broke. I was wondering what banging noise was when I hit the gas.
$17.00 to clean it and $68 to find out it was dirty
I wish I thought about it before I had it towed in cuz my mothers car was doing the same thing and I cleaned hers and it was fin after that. She has a 2000 Celica
Thanks, jason
teke184
06-16-2006, 03:10 PM
don't oil your K&N so much.
that's most likely why it was dirty.
robvas
06-16-2006, 03:53 PM
My car did the same thing, but some days it drove fine. Ended up being the battery.
