383TransAm
06-14-2006, 06:17 PM
I need some help with a table in my tune.
This is my Startup Enrichmet vs. Coolant Temp. table:
Deg. C % Change to....
116.........5.08
104.........5.08
92.........14.84
80.........14.84
68.........19.14
56.........28.13
44.........31.25
32.........39.84
20.........62.50
8...........75.00
-4..........85.94
-16........92.19
-28........99.61
-40........14.06
My problem is I'm fouling out my pulgs in the 1st few minuets of the car starting and I'm wondering if this is my problem?
This is what I have:
LT-1/383
6-Speed
AFR 190's
52mm TB
SVO 42lb
Cam. 228/234 Dur @ .050 .529/.522 LIft w/ 1.5 Rockers I Have 1.6 108* LSA
2.02/1.60 Valves
Adj. fuel regulator set @ 45lbs
Hooker LT's
The car ran great for the 1st few minuets then started getting rough from the plugs getting fouled with fuel.
LMN if there is any other info that I need to give.
116.........5.08
104.........5.08
92.........14.84
80.........14.84
68.........19.14
56.........28.13
44.........31.25
32.........39.84
20.........62.50
8...........75.00
-4..........85.94
-16........92.19
-28........99.61
-40........14.06
LT-1/383
6-Speed
AFR 190's
52mm TB
SVO 42lb
2.02/1.60 Valves
Hooker LT's
