blackztpi
06-14-2006, 01:21 PM
i was wondering if i could load info from a pcm that has been edited by using lt1 edit onto my tunercat program? would everything come up like normal, or would something bind?
LT1 editr to tunercat questionblackztpi 06-14-2006, 01:21 PM i was wondering if i could load info from a pcm that has been edited by using lt1 edit onto my tunercat program? would everything come up like normal, or would something bind? StickMaster 06-14-2006, 03:08 PM Don't think you'd have a problem there is a program out to conver the .lt1 (lt1edit) file to a .bin (tunercat) file and vice versa s_willis 06-14-2006, 03:41 PM i was wondering if i could load info from a pcm that has been edited by using lt1 edit onto my tunercat program? would everything come up like normal, or would something bind? No need to convert it, TC will run a LT1 file, when opening a file just click on the dropdown and select .LT1 extension and go from there. StickMaster 06-14-2006, 07:29 PM Well there ya go and to go vice versa theres a converter...p.s. s willis you have 666 posts. lol blackztpi 06-14-2006, 10:55 PM well, i wouldn't think i would have to convert anything.... i can upload the pcm data on tunercat and it SHOULD upload all the data into the tunercat tables automatically. reason i say is because i want a dyno tune at speed inc, but i don't want to buy lt1 edit to play with it if i ever need. s_willis 06-15-2006, 07:48 AM well, i wouldn't think i would have to convert anything.... i can upload the pcm data on tunercat and it SHOULD upload all the data into the tunercat tables automatically. reason i say is because i want a dyno tune at speed inc, but i don't want to buy lt1 edit to play with it if i ever need. My mistake, I thought you wanted to read an lt1 file with tunercat. To answer your question yes you can and no notheing wierd will happen | ||
