ls1lover346
06-13-2006, 01:35 PM
hey i am new here and i was just kind of wondering wat do stock ls1's put to the ground. rwhp and rwtq. i am lookin at a 98z28 for $5800:D
stock 1998 A4 rwhp?ls1lover346 06-13-2006, 01:35 PM hey i am new here and i was just kind of wondering wat do stock ls1's put to the ground. rwhp and rwtq. i am lookin at a 98z28 for $5800:D teke184 06-13-2006, 01:44 PM 98 auto....in good shape...280-300rwhp is about the range. not sure on torque. PWR-TRIP 06-13-2006, 02:45 PM I remember reading somewhere that it had 296 at the wheels. couldn't tell you the torque tho sorry. V6toZ28 06-13-2006, 02:48 PM I've seen 'em dyno as low as 265 and as high as 300 It's rare that you will see an A4 at 300 or higher stock. danziger 06-13-2006, 05:32 PM 280ish rwhp... mook99TA 06-13-2006, 05:45 PM I have a 99 A4 that dynoed@ 312hp stock and 308tq teke184 06-13-2006, 06:08 PM as well as every dyno is different. only way to truely compare is if all cars were on the same dyno, with the same air temp and humidity, and the same amount of heat soak. dyno numbers are nice for keyboard drag racing. mook99TA 06-13-2006, 06:28 PM as well as every dyno is different. only way to truely compare is if all cars were on the same dyno, with the same air temp and humidity, and the same amount of heat soak. dyno numbers are nice for keyboard drag racing. agreed V6toZ28 06-14-2006, 12:33 AM and dont forget, bigger stalls loose more hp :P But then it wouldn't be stock. SFB767 06-14-2006, 04:38 AM I remember reading somewhere that it had 296 at the wheels. couldn't tell you the torque tho sorry. That's what mine put to the wheels with a Magnaflow muffler. It made 296/314. I need to get some new numbers with the new mods.:cool: darrens99formul 06-14-2006, 04:31 PM I've seen 'em dyno as low as 265 and as high as 300 It's rare that you will see an A4 at 300 or higher stock. No offfense but if I saw any LS1 dyno 265 I would question either the car or the dyno for some flaws. Normal is in the 275-290 rwhp range. A few may be in the 290-305 range but 275-290 is right around where they should be on a dynojet and in decent weather. 01/02 models will dyno slightly higher and those are more likely to see 300+. DIYAR21 06-15-2006, 01:12 AM so how about a M6 2000 trans am with 34k miles BONE STOCK??? SFB767 06-15-2006, 04:40 AM so how about a M6 2000 trans am with 34k miles BONE STOCK??? Go and put it on "The Dreambreaker" and find out.:D darrens99formul 06-15-2006, 09:03 AM so how about a M6 2000 trans am with 34k miles BONE STOCK??? If it's in good running condition, I would guess 300-305 rwhp | ||
