Crank Shaft Sensor
skifast87
06-13-2006, 11:08 AM
I have a 2002 z28 so as you all know it has the LS1. The Crank shaft position sensor has gone bad in my car. Has any one ever changed one of these here. Also would you recomend just taking it some where? Or is it a simple job?
PS its a 6 speed if that matters in this case.
2001NBMZ28
06-13-2006, 11:41 AM
CKP sensor itself is easy to replace - but you need to remove the starter to get to it, then a CKP variation learn procedure has to be done with a scan tool.
skifast87
06-13-2006, 10:13 PM
what is the CKP variation learn procedure and waht does it do. i have a scan tool however im pretty sure it does not do that.
2001NBMZ28
06-15-2006, 01:35 PM
Basically it calibrates the new sensor to the car. I should've said Tech II instead of scan tool. I think some programers...like HP Tuners and others might do it, but not sure. If you have to bring it to the dealer for the realearn they'll probably charge you for a diagnostic fee and the relearn anyway - so might be easier (but more expensive) to have them replace it for you.
rwb
06-15-2006, 05:08 PM
After you install it, just drive it. I did that a couple of weeks ago. Mine works fine. If not just reset your computer by pulling the ign fuse and the fuel pump fuse and turning the car on but not starting it. Let it set for 5 or so minutes, turn key off and replace fuses. It will relearn then.
2001NBMZ28
06-15-2006, 05:33 PM
Never replaced one myself - just read the procedures out of my Helms. If you try it yourself and need to reset the PCM:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
skifast87
06-15-2006, 09:52 PM
Thanks guys. I think i am just gonna save my self the trouble and get some one to do it since i dont have the tech tool.
