Black305RS
06-12-2006, 02:49 PM
can someone show me a picture with the location of the maf burnoff relay on it or a more detailed location for it.. i was told it was on the driverside firewall and that it uses the same relay as the fuel pump. i replaced both relays there and i still havfe the code.
Black305RS
06-12-2006, 03:06 PM
nevermind i cleared the codes again and its off....for now.
Pneumatic_Tire
06-12-2006, 07:56 PM
The light will be back on. It wouldn't be a thirdgen without the check engine light on.
89Vert
06-12-2006, 07:59 PM
I occationally get a burn off relay code, not the end of the world
Kwiksilverz28
06-12-2006, 08:31 PM
Replace the relay, and blow out the maf. Carefully.
If that does not work, swap in a known good maf. Autozone can test the maf's.....I think. I know they can test ignition modules....
IROC-T
06-12-2006, 09:52 PM
If it comes back, or you still are haveing a problem try these: http://web.camaross.com/forums/search.php?searchid=1087297 They may help.:)
Jim85IROC
06-13-2006, 09:44 AM
Buying a Wells SU-145 MAF will fix your problem, because it uses an LT1-style MAF that doesn't need that silly burnoff sequence.
