JakeRobb 06-10-2006, 06:39 PM So I got new tires this weekend (http://web.camaross.com/forums/showthread.php?t=455202), and my car was up on a lift for the first time since I bought it. I took the opportunity to snap some pictures of the underside of the car, which I've never gotten a good look at before. There are a few taken from the sides as well, just to get a good perspective.
I have 7-megapixel versions of these. It seems to me that they could be somewhat informative. If anyone wants a high-res copy, feel free to ask.
Other than the 3" Corsa catback, everything you see here is completely stock.
View from rear of car:
http://homepage.mac.com/jakerobb/camaro/pictures/newtires-underneath.jpg
View of left rear spring from behind the tire.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/3.jpg
View of right rear spring, standing where the right rear tire would be if it weren't removed:
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/4.jpg
View of the front right brake/suspension assembly, tire removed:
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/5.jpg
View of the left rear wheel/brake/suspension/axle. Taken from right under the muffler.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/6.jpg
View of the bottom of the engine, from the front, looking up. Crank pulley front and center.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/7.jpg
View of tranny, cats, and oil filter. Looks like I have a little leak, or maybe the oil change guys are a little sloppy. Taken from beneath the driver's door.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/8.jpg
View of the rear suspension including stock panhard bar, taken from just behind the right rear brake disc.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/9.jpg
Rear end of the driveshaft where it connects to the diff, from the right side of the car. A section of exhaust pipe is visible too.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/10.jpg
JakeRobb 06-10-2006, 06:40 PM Fuel filter and brake lines, looking left from beneath the driveshaft.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/11.jpg
Similar to previous, angled more towards the rear of the car. Rear shock and other suspension components are visible.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/12.jpg
View of right rear suspension bump stop (showing how close it is to the tire), taken from behind the tire.
http://homepage.mac.com/jakerobb/camaro/pictures/underneath/14.jpg
fredmr39 06-10-2006, 06:56 PM why post these? as reference?
EDIT: sorry I just don't see how these could be of any use...
JakeRobb 06-10-2006, 06:57 PM I have 7-megapixel versions of these. It seems to me that they could be somewhat informative. If anyone wants a high-res copy, feel free to ask.
Check that out, I answered your question before you asked it. ;)
JakeRobb 06-10-2006, 07:02 PM More specifically, I posted these because lots of guys have 4th-gens, but not everyone has time to get under the car and look when they want to see how something is put together. I've owned my car for almost a year now, and this is the first time I've been underneath it. I know I would have liked to get a look at these pictures back when I bought the car, and I'm offering them up for anyone else who wants to know what it looks like under there.
I have a pretty nice camera and plenty of hosting space on the web, so I thought I would share these.
fredmr39 06-10-2006, 07:03 PM ah! -- I read it as the 7 megs could be more informative..or something? Didn't read into it much because my mind sees pictures and prefers those over words -- looks nice and clean under there btw
MarcR94v6 06-10-2006, 07:05 PM I find this to be quite useful. It's good to see the underside of the car and know what's what. Not many pictures like this out there, could be used as a good reference.
JakeRobb 06-10-2006, 07:06 PM looks nice and clean under there btw
Thanks. I was glad to discover that myself. The car has never been driven in snow, which is saying something considering that I'm in Michigan. With 56,000 miles on it, I can hardly complain about how things look under there.
SFB767 06-10-2006, 07:12 PM Pertaining to the underside picture of your engine and transmission:
That oil is probably seeping from a faulty gasket/manifold due to not totally sealing its perimeter from the factory.
My car has the same seepage. Every time I change my oil, I wipe it all down and the next time I change it, it's back. I think I'm only losing about 2 ounces of oil at the most and my mech. says it's not a big deal.
JakeRobb 06-10-2006, 07:13 PM My car has the same seepage. Every time I change my oil, I wipe it all down and the next time I change it, it's back. I think I'm only losing about 2 ounces of oil at the most and my mech. says it's not a big deal.
Thanks, I was hoping somebody would be able to fill me in on that.
ws6transam 10-19-2006, 09:51 PM Yes, helpful. However there is one particular angle that I need which is obscured by the torque arm. It's the emergency brake cable mounts and the rear seat belt stud mounting brackets. I'm trying to adapt some fourth-gen speed parts to my third-gen and it looks as if the transmission tunnels are slightly different.
ROADRAGE 10-20-2006, 02:57 AM Is that a salvage/rebuilt car?
nodnarb481 10-20-2006, 06:58 AM damn i love those ealge F1s.. saw them on a corvette one and it looked so awesome.. too bad i cant afford them
ws6transam 10-20-2006, 08:29 AM Is that a salvage/rebuilt car?
No salvage, but yes, I guess you can say its rebuilt. The quest to go ever faster has resulted in the replacement of everything that twists, turns, or otherwise rotates.
Now it looks as if I need to cut open the transmission tunnel in order to widen it so that I can clear the new torque arm design.
...or were you referring to Jake's beautiful Camaro which is one of the finest in Meridian Township?
2000GTP 10-20-2006, 11:14 AM Very clean underbody. I'm surprised it took you so long to look under there. That was one of the first places I would check when I was on the hunt for an f-body since I am in the Chicago area and alot of the cars I looked at were in pretty poor shape due to road salt abuse.
GRNcamaro 10-20-2006, 01:02 PM the underbody of my car looks just like that but the wheel wells need to be replaced becuase rust ate them. i dont think the undercoating was applied correctly becuase the undercoating turned to big blisters
JakeRobb 10-20-2006, 01:09 PM Is that a salvage/rebuilt car?
If you're talking about my car, no -- it's a clean title, all original except for the mods listed in my sig.
:D
Thanks Dan!
ws6transam 10-21-2006, 12:00 AM I'm getting to where I should switch from listing my mods to listing what is still stock.
"Original T-tops"
"Original carpet"
"Original retractable headlamp assemblies(rebuilt once)".
"Original power antenna assembly (repaired twice)"
Brangeta 10-28-2006, 02:15 AM I like the pics, thanks for taking them. Your underbody doesn't look bad, but it doesn't look great to me. It might be because you live in Michigan and I live in Texas where it is much drier.
Have you thought of having some sort of anti-corrosion coating or something sprayed on? I don't know much about them. My '95 Z28 came with it from the factory.
Here's 2 pics from today when I picked it up from the bodyshop; it was hit nearly 6 weeks ago by a Jeep Cherokee while it was parallel parked, so I just finally got it back. Note the multiple slowwwwww oil leaks :lol:
http://photos-310.ak.facebook.com/ip002/v47/66/95/18800375/n18800375_30978310_2344.jpg
http://photos-311.ak.facebook.com/ip002/v47/66/95/18800375/n18800375_30978311_2683.jpg
Looks pretty good considering I really don't do anything special with it. Just wash it, garage it, and oil change it. 75,000 miles on it and it still looks pretty new :)
Brangeta 10-28-2006, 02:27 AM Here's another one, but you can't see much:
http://photos-306.ak.facebook.com/ip002/v47/66/95/18800375/n18800375_30978306_1047.jpg
I have these in high-res as well if someone wants them for some reason. The car is fully stock, no mods.
shoebox 10-28-2006, 10:03 AM Why not just put these on a website? Picture threads kill people on dial-up.
Bayer-Z28 10-28-2006, 10:39 AM GSD3's Huh?!...:cool:... Great tires. Car is very clean too.. :thumb:
Injuneer 10-28-2006, 01:54 PM How about we change the title of the thread, so it represents more accurately your purpose for posting them.
I agree with Shoebox, using links to a website is a better way to handle things like this.
ROADRAGE 10-31-2006, 12:38 AM No salvage, but yes, I guess you can say its rebuilt. The quest to go ever faster has resulted in the replacement of everything that twists, turns, or otherwise rotates.
No, not yours, I know all about your car:p
:D
Thanks Dan!
I was just wondering why the k-member was painted with the v8 on it. Looks like something a salvage yard would do. Thought the k member had been replaced or something.
